first partion is labled “overlay” second partition labled “storage”
/dev/mmcblk0p2 on /tmp/mountd/disk1_part1 type ext4 (rw,relatime,data=ordered)
/dev/mmcblk0p1 on /tmp/mountd/disk1_part2 type ext4 (rw,relatime,data=ordered)
This is created using exroot, right? Can you change manually?
Sd card was partitioned On an earlier verison of openwrt and extroot was configured for that older version. This was a fresh install with slate ax beta 8 and popping that older card in.
But does it work normally? Or no?
You can go to luci->system and change the /overlay mount point directly. Does this work?
yes it still works normally. now that I think about it further it’s probably the better choice to mount the storage first. Just wanted to make a note of it if it was happening with other sdcards of different names and wasn’t the intended purpose.
