Hello, i don't know why but i can't access to http://192.168.8.1/ on Microsoft Edge browser only, i've tried to delete the cash and even full reset to the browser but i still have the same issue.
Can you open console and type ipconfig /all
i am on mac i typed: ifconfig
and i got this result:
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384
options=1203<RXCSUM,TXCSUM,TXSTATUS,SW_TIMESTAMP>
inet 127.0.0.1 netmask 0xff000000
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
nd6 options=201<PERFORMNUD,DAD>
gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280
stf0: flags=0<> mtu 1280
anpi0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=400<CHANNEL_IO>
ether 02:8d:79:5b:4a:9a
media: none
status: inactive
anpi2: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 02:8d:79:5b:4a:9c
media: none
status: inactive
anpi1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 02:8d:79:5b:4a:9b
media: none
status: inactive
en4: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 02:8d:79:5b:4a:7a
media: none
status: inactive
en5: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 02:8d:79:5b:4a:7b
media: none
status: inactive
en6: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 02:8d:79:5b:4a:7c
media: none
status: inactive
en1: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
options=460<TSO4,TSO6,CHANNEL_IO>
ether 36:fe:ea:45:85:40
media: autoselect <full-duplex>
status: inactive
en2: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 36:fe:ea:45:85:44
status: inactive
en3: flags=8963<UP,BROADCAST,SMART,RUNNING,PROMISC,SIMPLEX,MULTICAST> mtu 1500
ether 36:fe:ea:45:85:48
status: inactive
ap1: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=6460<TSO4,TSO6,CHANNEL_IO,PARTIAL_CSUM,ZEROINVERT_CSUM>
ether f2:6e:fe:3f:31:12
media: autoselect (none)
status: inactive
en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether 4e:a9:7c:70:6d:c7
inet6 fe80::1c53:55a:ee73:7db5%en0 prefixlen 64 secured scopeid 0xe
inet 192.168.8.181 netmask 0xffffff00 broadcast 192.168.8.255
media: autoselect
status: active
bridge0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
options=63<RXCSUM,TXCSUM,TSO4,TSO6>
Configuration:
id 0:0:0:0:0:0 priority 0 hellotime 0 fwddelay 0
maxage 0 holdcnt 0 proto stp maxaddr 100 timeout 1200
root id 0:0:0:0:0:0 priority 0 ifcost 0 port 0
ipfilter disabled flags 0x0
member: en1 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 10 priority 0 path cost 0
member: en2 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 11 priority 0 path cost 0
member: en3 flags=3<LEARNING,DISCOVER>
ifmaxaddr 0 port 12 priority 0 path cost 0
media: <unknown type>
status: inactive
awdl0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
ether aa:92:4c:c2:5b:d1
inet6 fe80::a892:4cff:fec2:5bd1%awdl0 prefixlen 64 scopeid 0x10
media: autoselect
status: active
llw0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500
inet6 fe80::a892:4cff:fec2:5bd1%llw0 prefixlen 64 scopeid 0x11
utun0: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1500
inet6 fe80::8d2a:38d:6480:d251%utun0 prefixlen 64 scopeid 0x12
utun1: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1380
inet6 fe80::6e9f:be95:d4be:1e71%utun1 prefixlen 64 scopeid 0x13
utun2: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 2000
inet6 fe80::1e42:4074:ef66:1183%utun2 prefixlen 64 scopeid 0x14
utun3: flags=8051<UP,POINTOPOINT,RUNNING,MULTICAST> mtu 1000
inet6 fe80::ce81:b1c:bd2c:69e%utun3 prefixlen 64 scopeid 0x15
Please try https://192.168.8.1/
instead.
Hello, i don't know how but now it worked, both with the https and http, for the first time since many weeks.
Again it is not working, on MS Edge only.
Could you please post a screenshot of the error message in Edge?
Could it be that you are using VPN/Proxy inside Edge?
VPN is disabeled, i've tried a full reset for Edge (without any extention) and it was not working, also in private mode.
And it just happens in Edge, correct?
Knowing up address was important to start.
Guess it's possible browser settings can cause. Ipv6, proxy and such.
yes only on edge.
it happened only after the last update of the device, never had this problem before.
