2.4 GHz Repeater Disconnects
Just received the Opal router GL-SFT1200. This is my second gl inet router exhibiting the exact same problem. My first was the older Slate 750ext
Here is the issue: When I connect the Opal to a 2.4 ghz access point to provide internet backhaul and connect my client devices to either the 2 or 5 GHz Opal ap, any traffic (browsing etc) will cause the Opal to drop the repeater side connection. The light goes from white to slow flashing “blue” (which really looks like a dim white!) And if I’m logged into the admin panel I see an error that the Opal has lost internet. Waiting a few mins, the connection reestablished, only for more traffic to cause the issue to repeat.
If I reverse the “stream” and connect the Opal to a 5ghz internet wifi backhaul and my client to the 2.4ghz Opal ap, everything works fine, so it doesn’t appear to be a 2.4 GHz radio problem, but strictly a repeater problem when using 2.4 as the internet link. (For these tests, I control all wifi units and all wifi devices are within line of site with each other, so this is not a reception problem. I’ve moved units around and tested multiple times)
I’ve tried this test using several different wifi aps as the internet source and compared this to connecting my clients directly and this is a very repeatable issue. The clients connecting directly to the internet sourced wifi ap have no problems browsing at all! Only when routing via the Opal using 2.4 GHz as backhaul does this problem appear. It’s very frustrating as I sometimes travel to places that only provide 2.4 GHz internet access.
This has been tested both on the 3.x and beta 4.x firmware. Same result across the board.
I see many posts about connection drops with repeater but none specifically call out this configuration (2.4 GHz as backhaul) so putting this out there for feedback.
I’m considering returning this unit if I can’t solve this as it’s clearly been an issue that’s plagued these series of routers for a long time.
That sounds like an issue with the uplinking AP for me. Maybe they don’t support another router inside the network, or they will not accept NAT, for example?
Since you can directly connect to the 2.4 GHz, it seems that they are running on different SSIDs - are they different networks as well?
The connection establishes and even some data moves through, the problem occurs when there is a “load” – like a lot of content on a page, etc. I can see some text and the odd image, but move more than a trivial amount of data and it dies.
As mentioned, this is my network, I’ve connected other devices that repeat (like my Pixel phone in hotspot mode to test) and there is no issue with this config, so no, it’s not the host network.
Can you post the log?
Here is a snippet from last up to down and back up again… the trigger is always loading a web page.
Sun Oct 22 15:44:37 2023 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta0)
Sun Oct 22 15:44:38 2023 user.notice relay: Reloading relay due to connected of wwan (wlan-sta0)
Sun Oct 22 15:44:38 2023 daemon.err dnscrypt-proxy[1919]: dnscrypt-proxy Unable to retrieve server certificates
Sun Oct 22 15:44:39 2023 user.notice relay: Reloading relay due to ifup of wwan (wlan-sta0)
Sun Oct 22 15:45:35 2023 daemon.info dnscrypt-proxy[1919]: dnscrypt-proxy Refetching server certificates
Sun Oct 22 15:45:36 2023 daemon.notice wpa_supplicant[8756]: wlan-sta0: WPA: Group rekeying completed with 66:d1:54:5e:0e:e0 [GTK=CCMP]
Sun Oct 22 15:45:36 2023 daemon.info lua: (...pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>WPA: Group rekeying completed with 66:d1:54:5e:0e:e0 [GTK=CCMP]
Sun Oct 22 15:45:36 2023 kern.info kernel: [  935.943687] lb-fmac 11000000.wifi-lb wlan-sta0: Add key for vif(0), key index : 2
Sun Oct 22 15:45:50 2023 daemon.err dnscrypt-proxy[1919]: dnscrypt-proxy Unable to retrieve server certificates
Sun Oct 22 15:46:51 2023 daemon.info dnscrypt-proxy[1919]: dnscrypt-proxy Refetching server certificates
Sun Oct 22 15:47:06 2023 daemon.err dnscrypt-proxy[1919]: dnscrypt-proxy Unable to retrieve server certificates
Sun Oct 22 15:47:09 2023 daemon.notice wpa_supplicant[8756]: wlan-sta0: CTRL-EVENT-DISCONNECTED bssid=66:d1:54:5e:0e:e0 reason=2
Sun Oct 22 15:47:09 2023 daemon.info lua: (...pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-DISCONNECTED bssid=66:d1:54:5e:0e:e0 reason=2
Sun Oct 22 15:47:09 2023 kern.warn kernel: [ 1029.446121] lmac[0] {CTXT-1} unlink from {VIF-0}: status=4 nb_vif=1
Sun Oct 22 15:47:09 2023 kern.warn kernel: [ 1029.446151] lmac[0] {CTXT-1} Delete channel context
Sun Oct 22 15:47:09 2023 kern.info kernel: [ 1029.452719] lb-fmac 11000000.wifi-lb wlan-sta0: Del key for vif(0), key index : 0
Sun Oct 22 15:47:09 2023 kern.info kernel: [ 1029.465254] lb-fmac 11000000.wifi-lb wlan-sta0: Del key for vif(0), key index : 1
Sun Oct 22 15:47:09 2023 kern.info kernel: [ 1029.473458] lb-fmac 11000000.wifi-lb wlan-sta0: Del key for vif(0), key index : 2
Sun Oct 22 15:47:09 2023 kern.info kernel: [ 1029.481960] lb-fmac 11000000.wifi-lb wlan-sta0: Del key for vif(0), key index : 3
Sun Oct 22 15:47:09 2023 kern.info kernel: [ 1029.489578] lb-fmac 11000000.wifi-lb wlan-sta0: Del key for vif(0), key index : 4
Sun Oct 22 15:47:09 2023 kern.info kernel: [ 1029.497192] lb-fmac 11000000.wifi-lb wlan-sta0: Del key for vif(0), key index : 5
Sun Oct 22 15:47:09 2023 daemon.notice netifd: Network device 'wlan-sta0' link is down
Sun Oct 22 15:47:09 2023 daemon.notice netifd: Interface 'wwan' has link connectivity loss
Sun Oct 22 15:47:09 2023 kern.warn kernel: [ 1029.555042] lmac[0] final dsss power is 27 ofdm power is 27
Sun Oct 22 15:47:09 2023 daemon.info lua: (...pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-SCAN-STARTED
Sun Oct 22 15:47:09 2023 kern.warn kernel: [ 1029.585879] lmac[0] final dsss power is 27 ofdm power is 27
Sun Oct 22 15:47:09 2023 daemon.notice netifd: wwan (4078): udhcpc: received SIGTERM
Sun Oct 22 15:47:09 2023 kern.warn kernel: [ 1029.616742] lmac[0] final dsss power is 27 ofdm power is 27
Sun Oct 22 15:47:10 2023 kern.warn kernel: [ 1029.647527] lmac[0] final dsss power is 27 ofdm power is 27
Sun Oct 22 15:47:10 2023 kern.warn kernel: [ 1029.678343] lmac[0] final dsss power is 27 ofdm power is 27
Sun Oct 22 15:47:10 2023 kern.warn kernel: [ 1029.709181] lmac[0] final dsss power is 27 ofdm power is 27
Sun Oct 22 15:47:10 2023 kern.warn kernel: [ 1029.740042] lmac[0] final dsss power is 27 ofdm power is 27
Sun Oct 22 15:47:10 2023 kern.warn kernel: [ 1029.770849] lmac[0] final dsss power is 27 ofdm power is 27
Sun Oct 22 15:47:10 2023 kern.warn kernel: [ 1029.801688] lmac[0] final dsss power is 27 ofdm power is 27
Sun Oct 22 15:47:10 2023 daemon.err lua: (...pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:1270) disconnected, wait reconnect...
Sun Oct 22 15:47:10 2023 daemon.notice netifd: Interface 'wwan' is disabled
Sun Oct 22 15:47:10 2023 kern.warn kernel: [ 1029.832556] lmac[0] final dsss power is 27 ofdm power is 27
Sun Oct 22 15:47:10 2023 kern.warn kernel: [ 1029.863404] lmac[0] final dsss power is 27 ofdm power is 27
Sun Oct 22 15:47:10 2023 daemon.info lua: (...pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-SCAN-RESULTS
Sun Oct 22 15:47:10 2023 daemon.info lua: (...pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>WPS-AP-AVAILABLE
Sun Oct 22 15:47:10 2023 daemon.notice wpa_supplicant[8756]: wlan-sta0: Trying to associate with 66:d1:54:5e:0e:e0 (SSID='riots' freq=2462 MHz)
Sun Oct 22 15:47:10 2023 daemon.info lua: (...pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>Trying to associate with 66:d1:54:5e:0e:e0 (SSID='riots' freq=2462 MHz)
Sun Oct 22 15:47:10 2023 kern.warn kernel: [ 1029.904839] lmac[0] final dsss power is 27 ofdm power is 27
Sun Oct 22 15:47:10 2023 kern.warn kernel: [ 1029.934909] lmac[0] {CTXT-2} Create channel context: freq=2462MHz bw=20MHz pwr=20dBm
Sun Oct 22 15:47:10 2023 kern.warn kernel: [ 1029.942796] lmac[0] {CTXT-2} link to {VIF-0}: status=0 nb_vif=0
Sun Oct 22 15:47:10 2023 kern.warn kernel: [ 1029.942825] lmac[0] final dsss power is 27 ofdm power is 27
Sun Oct 22 15:47:10 2023 kern.warn kernel: [ 1029.954463] lmac[0] rc_init: station_id=5 format_mod=2 pre_type=0 short_gi=1 max_bw=0
Sun Oct 22 15:47:10 2023 kern.warn kernel: [ 1029.962386] lmac[0] rc_init: nss_max=1 mcs_max=7 r_idx_min=12 r_idx_max=12 no_samples=10
Sun Oct 22 15:47:10 2023 daemon.notice netifd: Network device 'wlan-sta0' link is up
Sun Oct 22 15:47:10 2023 daemon.notice netifd: Interface 'wwan' has link connectivity
Sun Oct 22 15:47:10 2023 daemon.notice wpa_supplicant[8756]: wlan-sta0: Associated with 66:d1:54:5e:0e:e0
Sun Oct 22 15:47:10 2023 daemon.notice wpa_supplicant[8756]: wlan-sta0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Sun Oct 22 15:47:10 2023 daemon.info lua: (...pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>Associated with 66:d1:54:5e:0e:e0
Sun Oct 22 15:47:10 2023 daemon.info lua: (...pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Sun Oct 22 15:47:10 2023 kern.info kernel: [ 1029.982205] lb-fmac 11000000.wifi-lb wlan-sta0: Add key for sta 5 (66:d1:54:5e:0e:e0)
Sun Oct 22 15:47:10 2023 kern.info kernel: [ 1029.991357] lb-fmac 11000000.wifi-lb wlan-sta0: Add key for vif(0), key index : 2
Sun Oct 22 15:47:10 2023 daemon.notice wpa_supplicant[8756]: wlan-sta0: WPA: Key negotiation completed with 66:d1:54:5e:0e:e0 [PTK=CCMP GTK=CCMP]
Sun Oct 22 15:47:10 2023 daemon.info lua: (...pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>WPA: Key negotiation completed with 66:d1:54:5e:0e:e0 [PTK=CCMP GTK=CCMP]
Sun Oct 22 15:47:10 2023 daemon.notice wpa_supplicant[8756]: wlan-sta0: CTRL-EVENT-CONNECTED - Connection to 66:d1:54:5e:0e:e0 completed [id=0 id_str=]
Sun Oct 22 15:47:10 2023 daemon.info lua: (...pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:548) <3>CTRL-EVENT-CONNECTED - Connection to 66:d1:54:5e:0e:e0 completed [id=0 id_str=]
Sun Oct 22 15:47:10 2023 user.notice mwan3[10838]: Execute ifdown event on interface wwan (unknown)
Sun Oct 22 15:47:10 2023 user.info mwan3track[4989]: Detect ifdown event on interface wwan (wlan-sta0)
Sun Oct 22 15:47:10 2023 user.notice mwan3track[4989]: Interface wwan (wlan-sta0) is offline
Sun Oct 22 15:47:12 2023 user.notice firewall: Reloading firewall due to ifdown of wwan ()
Sun Oct 22 15:47:12 2023 user.notice relay: Reloading relay due to disconnected of wwan (wlan-sta0)
Sun Oct 22 15:47:13 2023 daemon.info lua: (...pkg-mips_siflower/gl-sdk4-repeater/usr/sbin/repeater:1239) connected to 'riots(66:d1:54:5e:0e:e0)' channel: 11, spent 3s
Sun Oct 22 15:47:13 2023 daemon.notice netifd: Interface 'wwan' is enabled
Sun Oct 22 15:47:13 2023 daemon.notice netifd: Interface 'wwan' is setting up now
Sun Oct 22 15:47:13 2023 daemon.notice netifd: wwan (11401): udhcpc: started, v1.29.3
Sun Oct 22 15:47:13 2023 daemon.notice netifd: wwan (11401): udhcpc: sending discover
Sun Oct 22 15:47:13 2023 daemon.notice netifd: wwan (11401): udhcpc: sending select for 192.168.10.95
Sun Oct 22 15:47:13 2023 user.notice relay: Reloading relay due to ifdown of wwan ()
Sun Oct 22 15:47:13 2023 daemon.notice netifd: wwan (11401): udhcpc: lease of 192.168.10.95 obtained, lease time 86400
Sun Oct 22 15:47:14 2023 daemon.warn dnsmasq[1826]: no servers found in /tmp/resolv.conf.auto, will retry
Sun Oct 22 15:47:14 2023 daemon.notice netifd: Interface 'wwan' is now up
Sun Oct 22 15:47:14 2023 daemon.info dnsmasq[1826]: reading /tmp/resolv.conf.auto
Sun Oct 22 15:47:14 2023 daemon.info dnsmasq[1826]: using local addresses only for domain test
Sun Oct 22 15:47:14 2023 daemon.info dnsmasq[1826]: using local addresses only for domain onion
Sun Oct 22 15:47:14 2023 daemon.info dnsmasq[1826]: using local addresses only for domain localhost
Sun Oct 22 15:47:14 2023 daemon.info dnsmasq[1826]: using local addresses only for domain invalid
Sun Oct 22 15:47:14 2023 daemon.notice netifd: wwan (11401): /lib/netifd/dhcp.script: line 62: netclash: not found
Sun Oct 22 15:47:14 2023 daemon.info dnsmasq[1826]: using local addresses only for domain bind
Sun Oct 22 15:47:14 2023 daemon.info dnsmasq[1826]: using local addresses only for domain lan
Sun Oct 22 15:47:14 2023 daemon.info dnsmasq[1826]: using nameserver 1.1.1.3#53
Sun Oct 22 15:47:14 2023 daemon.info dnsmasq[1826]: using nameserver 1.0.0.3#53
Sun Oct 22 15:47:14 2023 user.info mwan3track[4989]: Lost 5 ping(s) on interface wwan (wlan-sta0)
Sun Oct 22 15:47:15 2023 user.notice mwan3[11491]: Execute ifup event on interface wwan (wlan-sta0)
Sun Oct 22 15:47:16 2023 user.notice mwan3[11491]: Starting tracker on interface wwan (wlan-sta0)
Sun Oct 22 15:47:16 2023 user.notice mwan3track[4989]: Stopping mwan3track for interface "wwan"
Sun Oct 22 15:47:19 2023 user.info mwan3rtmon[2275]: Detect rtchange event.
Sun Oct 22 15:47:20 2023 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta0)
Sun Oct 22 15:47:20 2023 user.notice relay: Reloading relay due to connected of wwan (wlan-sta0)
Sun Oct 22 15:47:21 2023 user.notice relay: Reloading relay due to ifup of wwan (wlan-sta0)
As a side note my Mikrotik router (the backhaul ap in this test) shows a log msg of “disconnected, extensive data loss”.
I’m using the GL-SFT1200 as a repeater and I have slowdown problems. Out of 290MB it only delivers 50MB of speed as a repeater and no one identifies the problem.
I want to know these settings:
  1. 2.4G wifi channel
  2. Is your 2.4G and 5G wifi using the same SSID and key on Mikrotik?
  3. Do you have some settings e.g. band steering in your Mikrotik router?
The previously attached log output for an AP that advertises multiple SSIDs on Ch. 11. However, I also tested this on another 2Ghz only AP with only one SSID on ch. 3 and had the same results.
  1. Is your 2.4G and 5G wifi using the same SSID and key on Mikrotik?
The MT AP advertises multiple different network SSIDs, but for the one I was testing, I used a dedicated 2G SSID that did not have a corresponding 5G SSID.
  1. Do you have some settings e.g. band steering in your Mikrotik router?
MT routers don’t support this as far as I know. I have nothing special set on either of the APs I tested with and no other devices are experiencing problems.
Channel 11 should be fine. But don’t use channel 3. Use 1, 6 or 11 only.
@dengxinfa can you have a check of the 2.4G wifi disconnect log?
Just thought I’d add: I just received from Amazon the Beryl GL-MT1300 and configured it exactly the same as the troubled Opal, using all the same clients and backhaul access points – and so far it works flawlessly. So either I have a bum Opal or there is something fundamentally wrong with that product line and my setup.
I’m going to be returning the Opal… :frowning:
Hi everyone! I’m facing the same issue here: my repeater mode works fine with my home Wi-Fi 5ghz network, but it loses internet connection after a few minutes on the 2.4ghz one. I don’t want to use the 5ghz radio for repeater mode because I want to keep it free. Has anyone found a solution for this? I appreciate your help!
Do you mean SFT1200? Seems you have different routers.
Do you have the logs?
Long shot, but do you notice if the BSSID is changing when on 2.4Ghz? Jump over to Luci and remove the BSSID for that wireless connection (think I’ve also seen it with a tick box as ‘lock BSSID’ on some version of OpenWRT).
Hello @alzhao! Yest, this problem only happens with the STF1200, just like OP.
I believe @McMuckle nailed it: I’ve set the repeater to lock BSSID, since I have two AP broadcasting the same SSID and OPAL seems to work just fine now, great idea! It seems this is problem related to the OPAL software, since this is not an issue at all with the Beryl.
@alzhao do you think there will be an FW update for OPAL in the near future? It might fix this issue and keep the device up to date comparing to your other routers. I know this is an affordable device, with a low spec hardware but it has great potential, especially with emerging countries like mine. It still runs OpenWrt 18.06 with Kernel Version 4.14.90.
Thank you very much guys!
It will have firmware update. But the openwrt version and kernel version cannot be changed. We can only update the applications on top of them.
