2.4GHz WiFi stops working on my X750 (spitz)
The lights on the router never change from the photo and the lights come on like that as soon as I plug in power.
The power and 2G lights are always off and (it’s not clear from the photo) the WAN and 5G lights are on but about half or even a quarter of the brightness of the LTE light.
Wifi settings
Kernel log
[    0.000000] Linux version 4.14.241 (glinet@glinet) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11257-5090152ae3)) #0 Thu Jul 29 19:50:28 2021
[    0.000000] bootconsole [early0] enabled
[    0.000000] CPU0 revision is: 00019374 (MIPS 24Kc)
[    0.000000] MIPS: machine is GL.iNet GL-X750 (NOR)
[    0.000000] SoC: Qualcomm Atheros QCA9533 ver 2 rev 0
[    0.000000] Determined physical RAM map:
[    0.000000]  memory: 08000000 @ 00000000 (usable)
[    0.000000] Initrd not found or empty - disabling initrd
[    0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x0000000000000000-0x0000000007ffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000007ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[    0.000000] On node 0 totalpages: 32768
[    0.000000] free_area_init_node: node 0, pgdat 805d7aa0, node_mem_map 81007ec0
[    0.000000]   Normal zone: 256 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 32768 pages, LIFO batch:7
[    0.000000] random: get_random_bytes called from start_kernel+0x98/0x494 with crng_init=0
[    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[    0.000000] pcpu-alloc: [0] 0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 32512
[    0.000000] Kernel command line: rootfstype=squashfs,jffs2 rootfstype=squashfs,jffs2
[    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Writing ErrCtl register=00000000
[    0.000000] Readback ErrCtl register=00000000
[    0.000000] Memory: 122404K/131072K available (4427K kernel code, 156K rwdata, 1008K rodata, 1244K init, 218K bss, 8668K reserved, 0K cma-reserved)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS: 51
[    0.000000] CPU clock: 650.000 MHz
[    0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 5880801374 ns
[    0.000009] sched_clock: 32 bits at 325MHz, resolution 3ns, wraps every 6607641598ns
[    0.008250] Calibrating delay loop... 432.53 BogoMIPS (lpj=2162688)
[    0.074862] pid_max: default: 32768 minimum: 301
[    0.079929] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.086902] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.098531] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.108950] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.115476] pinctrl core: initialized pinctrl subsystem
[    0.122131] NET: Registered protocol family 16
[    0.133494] PCI host bridge /ahb/pcie-controller@180c0000 ranges:
[    0.139929]  MEM 0x0000000010000000..0x0000000013ffffff
[    0.145477]   IO 0x0000000000000000..0x0000000000000000
[    0.166845] PCI host bridge to bus 0000:00
[    0.171172] pci_bus 0000:00: root bus resource [mem 0x10000000-0x13ffffff]
[    0.178461] pci_bus 0000:00: root bus resource [io  0x0000]
[    0.184334] pci_bus 0000:00: root bus resource [??? 0x00000000 flags 0x0]
[    0.191489] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[    0.199863] pci 0000:00:00.0: [168c:0050] type 00 class 0x028000
[    0.199922] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
[    0.199976] pci 0000:00:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
[    0.200053] pci 0000:00:00.0: supports D1
[    0.200063] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
[    0.200268] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 00
[    0.200295] pci 0000:00:00.0: BAR 0: assigned [mem 0x10000000-0x101fffff 64bit]
[    0.208049] pci 0000:00:00.0: BAR 6: assigned [mem 0x10200000-0x1020ffff pref]
[    0.218207] clocksource: Switched to clocksource MIPS
[    0.224518] NET: Registered protocol family 2
[    0.229358] IP idents hash table entries: 2048 (order: 2, 16384 bytes)
[    0.236879] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.244283] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.251002] TCP: Hash tables configured (established 1024 bind 1024)
[    0.257846] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.264055] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.270933] NET: Registered protocol family 1
[    0.275565] PCI: CLS 0 bytes, default 32
[    0.278416] Crashlog allocated RAM at address 0x3f00000
[    0.285148] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[    0.296891] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.303087] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.323471] io scheduler noop registered
[    0.327609] io scheduler deadline registered (default)
[    0.335172] pinctrl-single 1804002c.pinmux: 576 pins at pa b804002c size 72
[    0.343190] gpio-export gpio-export: 3 gpio(s) exported
[    0.349443] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[    0.358443] console [ttyS0] disabled
[    0.362249] 18020000.uart: ttyS0 at MMIO 0x18020000 (irq = 9, base_baud = 1562500) is a 16550A
[    0.371366] console [ttyS0] enabled
[    0.454887] bootconsole [early0] disabled
[    0.568436] m25p80 spi0.0: w25q128 (16384 Kbytes)
[    0.624874] 4 fixed-partitions partitions found on MTD device spi0.0
[    0.701084] Creating 4 MTD partitions on "spi0.0":
[    0.758576] 0x000000000000-0x000000040000 : "u-boot"
[    0.818921] 0x000000040000-0x000000050000 : "u-boot-env"
[    0.883407] 0x000000050000-0x000000060000 : "art"
[    0.940635] 0x000000060000-0x000001000000 : "firmware"
[    1.005466] 2 uimage-fw partitions found on MTD device firmware
[    1.076577] Creating 2 MTD partitions on "firmware":
[    1.136118] 0x000000000000-0x0000001d0000 : "kernel"
[    1.196368] 0x0000001d0000-0x000000fa0000 : "rootfs"
[    1.256682] mtd: device 5 (rootfs) set to be root filesystem
[    1.325949] 1 squashfs-split partitions found on MTD device rootfs
[    1.400184] 0x000000c80000-0x000000fa0000 : "rootfs_data"
[    1.466674] spi-nand: unknown raw ID 00000000
[    1.518996] spi-nand: Failed to detect a SPI NAND (err = -19).
[    1.589576] libphy: Fixed MDIO Bus: probed
[    1.979310] ag71xx 19000000.eth: Could not connect to PHY device. Deferring probe.
[    2.748585] libphy: ag71xx_mdio: probed
[    3.078678] mdio-bus.0:1f: Found an AR934X built-in switch
[    3.144638] libphy: ar7240sw_mdio: probed
[    3.245784] ag71xx 1a000000.eth: connected to PHY at fixed-0:00 [uid=00000000, driver=Generic PHY]
[    3.353955] eth1: Atheros AG71xx at 0xba000000, irq 5, mode: gmii
[    3.429218] NET: Registered protocol family 10
[    3.487097] Segment Routing with IPv6
[    3.531115] NET: Registered protocol family 17
[    3.584443] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    3.739937] 8021q: 802.1Q VLAN Support v1.8
[    4.130399] ag71xx 19000000.eth: connected to PHY at mdio-bus.0:1f:04 [uid=004dd042, driver=Generic PHY]
[    4.245046] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode: mii
[    4.327381] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[    4.418737] Freeing unused kernel memory: 1244K
[    4.473101] This architecture does not have kernel memory protection.
[    4.618217] random: fast init done
[    5.559941] init: Console is alive
[    5.600964] init: - watchdog -
[    8.976190] kmodloader: loading kernel modules from /etc/modules-boot.d/*
[    9.453687] usbcore: registered new interface driver usbfs
[    9.519582] usbcore: registered new interface driver hub
[    9.583401] usbcore: registered new device driver usb
[    9.653845] exFAT: Version 1.2.9
[    9.729156] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    9.816803] SCSI subsystem initialized
[    9.867375] ehci-platform: EHCI generic platform driver
[    9.930361] ehci-platform 1b000000.usb: EHCI Host Controller
[    9.998358] ehci-platform 1b000000.usb: new USB bus registered, assigned bus number 1
[   10.092394] ehci-platform 1b000000.usb: irq 3, io mem 0x1b000000
[   10.188253] ehci-platform 1b000000.usb: USB 2.0 started, EHCI 1.00
[   10.263289] hub 1-0:1.0: USB hub found
[   10.308686] hub 1-0:1.0: 1 port detected
[   10.359875] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[   10.435862] ohci-platform: OHCI generic platform driver
[   10.501536] uhci_hcd: USB Universal Host Controller Interface driver
[   10.582698] usbcore: registered new interface driver usb-storage
[   10.657444] usbcore: registered new interface driver uas
[   10.722074] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[   10.808889] usb 1-1: new high-speed USB device number 2 using ehci-platform
[   10.902939] init: - preinit -
[   11.092358] hub 1-1:1.0: USB hub found
[   11.288929] hub 1-1:1.0: 4 ports detected
[   11.738479] usb 1-1.1: new high-speed USB device number 3 using ehci-platform
[   12.134094] random: procd: uninitialized urandom read (4 bytes read)
[   12.210908] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[   12.368591] scsi host0: usb-storage 1-1.1:1.0
[   12.585437] usb 1-1.2: new high-speed USB device number 4 using ehci-platform
[   12.676486] random: jshn: uninitialized urandom read (4 bytes read)
[   12.971993] random: jshn: uninitialized urandom read (4 bytes read)
[   13.164430] urandom_read: 1 callbacks suppressed
[   13.164438] random: jshn: uninitialized urandom read (4 bytes read)
[   13.340448] random: jshn: uninitialized urandom read (4 bytes read)
[   13.466960] random: jshn: uninitialized urandom read (4 bytes read)
[   13.548585] scsi 0:0:0:0: Direct-Access     Generic  STORAGE DEVICE   0233 PQ: 0 ANSI: 0
[   14.339259] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   14.669352] sd 0:0:0:0: [sda] Attached SCSI removable disk
[   15.469410] eth1: link up (1000Mbps/Full duplex)
[   15.526887] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[   17.791199] mount_root: loading kmods from internal overlay
[   17.937581] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[   18.024963] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[   21.171494] jffs2: notice: (501) jffs2_build_xattr_subsystem: complete building xattr subsystem, 20 of xdatum (3 unchecked, 17 orphan) and 59 of xref (17 dead, 0 orphan) found.
[   21.361171] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[   21.460126] block: extroot: not configured
[   21.652719] jffs2: notice: (499) jffs2_build_xattr_subsystem: complete building xattr subsystem, 20 of xdatum (3 unchecked, 17 orphan) and 59 of xref (17 dead, 0 orphan) found.
[   21.843836] mount_root: loading kmods from internal overlay
[   21.985344] kmodloader: loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[   22.090834] kmodloader: done loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[   24.378681] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[   24.471712] block: extroot: not configured
[   24.522332] mount_root: switching to jffs2 overlay
[   24.654164] overlayfs: upper fs does not support tmpfile.
[   24.724779] urandom-seed: Seeding with /etc/urandom.seed
[   24.900074] eth1: link down
[   24.951545] procd: - early -
[   24.988053] procd: - watchdog -
[   25.673449] urandom_read: 1 callbacks suppressed
[   25.673457] random: jshn: uninitialized urandom read (4 bytes read)
[   25.805402] procd: - watchdog -
[   25.843440] procd: - ubus -
[   26.174399] random: ubusd: uninitialized urandom read (4 bytes read)
[   26.255589] procd: - init -
[   31.044220] kmodloader: loading kernel modules from /etc/modules.d/*
[   31.245364] urngd: v1.0.2 started.
[   31.653124] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[   31.789077] tun: Universal TUN/TAP device driver, 1.6
[   31.852580] random: crng init done
[   31.948916] GobiNet: 2018-12-21/SWI_2.55
[   31.997509] usbcore: registered new interface driver GobiNet
[   32.192098] usbcore: registered new interface driver usbserial
[   32.262226] usbcore: registered new interface driver usbserial_generic
[   32.340597] usbserial: USB Serial support registered for generic
[   32.639568] usbcore: registered new interface driver GobiSerial
[   32.710767] usbserial: USB Serial support registered for GobiSerial
[   32.786007] GobiSerial: 2015-08-27/SWI_2.25:GobiSerial
[   33.200151] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   33.347258] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
[   33.687202] Netfilter messages via NETLINK v0.30.
[   33.801243] ip_set: protocol 6
[   33.953805] Mirror/redirect action on
[   34.069676] u32 classifier
[   34.102216]     input device check on
[   34.146076]     Actions configured
[   34.376681] GACT probability on
[   34.422697] Simple TC action Loaded
[   34.500692] fuse init (API version 7.26)
[   34.559865] usbcore: registered new interface driver cdc_acm
[   34.627786] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[   34.727397] usbcore: registered new interface driver cdc_ether
[   34.802416] usbcore: registered new interface driver cdc_ncm
[   34.876880] usbcore: registered new interface driver cdc_wdm
[   34.947842] Loading modules backported from Linux version v4.19.193-0-g1722257b8ece
[   35.039872] Backport generated by backports.git v4.19.193-1-0-gaa2cc8ea
[   35.122706] usbcore: registered new interface driver cp210x
[   35.189742] usbserial: USB Serial support registered for cp210x
[   35.278128] Ebtables v2.0 registered
[   35.323158] usbcore: registered new interface driver huawei_cdc_ncm
[   35.402578] ip_tables: (C) 2000-2006 Netfilter Core Team
[   35.469339] usbcore: registered new interface driver ipheth
[   35.735015] ctnetlink v0.93: registering with nfnetlink.
[   35.956770] qmi_wwan 1-1.2:1.4: cdc-wdm0: USB WDM device
[   36.020579] qmi_wwan 1-1.2:1.4: QuectelEC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
[   36.134488] qmi_wwan 1-1.2:1.4 wwan0: register 'qmi_wwan' at usb-1b000000.usb-1.2, WWAN/QMI device, 1a:01:86:86:b0:f1
[   36.262206] usbcore: registered new interface driver qmi_wwan
[   36.340235] usbcore: registered new interface driver rndis_host
[   36.415127] usbcore: registered new interface driver sierra
[   36.482162] usbserial: USB Serial support registered for Sierra USB modem
[   36.568736] usbcore: registered new interface driver sierra_net
[   36.656960] wireguard: WireGuard 1.0.20200611 loaded. See www.wireguard.com for information.
[   36.758348] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[   36.928751] xt_time: kernel timezone is -0000
[   37.281665] usbcore: registered new interface driver option
[   37.348631] usbserial: USB Serial support registered for GSM modem (1-port)
[   37.432666] option 1-1.2:1.0: GSM modem (1-port) converter detected
[   37.508177] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
[   37.591865] option 1-1.2:1.1: GSM modem (1-port) converter detected
[   37.667401] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
[   37.751169] option 1-1.2:1.2: GSM modem (1-port) converter detected
[   37.826699] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
[   37.910466] option 1-1.2:1.3: GSM modem (1-port) converter detected
[   37.986027] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB3
[   38.352198] PPP generic driver version 2.4.2
[   38.406641] PPP MPPE Compression module registered
[   38.466623] NET: Registered protocol family 24
[   38.579861] PCI: Enabling device 0000:00:00.0 (0000 -> 0002)
[   38.650143] ath10k_pci 0000:00:00.0: pci irq legacy oper_irq_mode 1 irq_mode 0 reset_mode 0
[   39.022814] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:00:00.0.bin failed with error -2
[   39.151331] ath10k_pci 0000:00:00.0: Falling back to user helper
[   52.903613] firmware ath10k!pre-cal-pci-0000:00:00.0.bin: firmware_loading_store: map pages failed
[   53.018609] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9887/hw1.0/firmware-6.bin failed with error -2
[   53.147067] ath10k_pci 0000:00:00.0: Falling back to user helper
[   53.428034] firmware ath10k!QCA9887!hw1.0!firmware-6.bin: firmware_loading_store: map pages failed
[   53.773675] ath10k_pci 0000:00:00.0: qca9887 hw1.0 target 0x4100016d chip_id 0x004000ff sub 0000:0000
[   53.884432] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
[   53.988056] ath10k_pci 0000:00:00.0: firmware ver 10.2.4-1.0-00047 api 5 features no-p2p,ignore-otp,skip-clock-init,mfp,allows-mesh-bcast crc32 62f7565f
[   54.184722] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9887/hw1.0/board-2.bin failed with error -2
[   54.310011] ath10k_pci 0000:00:00.0: Falling back to user helper
[   54.488644] firmware ath10k!QCA9887!hw1.0!board-2.bin: firmware_loading_store: map pages failed
[   54.609808] ath10k_pci 0000:00:00.0: board_file api 1 bmi_id N/A crc32 546cca0d
[   55.793437] ath10k_pci 0000:00:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal file max-sta 128 raw 0 hwcrypto 1
[   56.039703] ath: EEPROM regdomain: 0x0
[   56.039711] ath: EEPROM indicates default country code should be used
[   56.039714] ath: doing EEPROM country->regdmn map search
[   56.039727] ath: country maps to regdmn code: 0x3a
[   56.039732] ath: Country alpha2 being used: US
[   56.039736] ath: Regpair used: 0x3a
[   56.181199] usbcore: registered new interface driver rt2800usb
[   56.391039] ath: EEPROM regdomain: 0x0
[   56.391049] ath: EEPROM indicates default country code should be used
[   56.391052] ath: doing EEPROM country->regdmn map search
[   56.391066] ath: country maps to regdmn code: 0x3a
[   56.391071] ath: Country alpha2 being used: US
[   56.391074] ath: Regpair used: 0x3a
[   56.404868] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[   56.406574] ieee80211 phy1: Atheros AR9531 Rev:2 mem=0xb8100000, irq=13
[   56.578866] kmodloader: done loading kernel modules from /etc/modules.d/*
[   72.743036] IPv6: ADDRCONF(NETDEV_UP): lo: link is not ready
[   73.734033] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[   74.827294] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[   75.053443] br-lan: port 1(eth1) entered blocking state
[   75.116151] br-lan: port 1(eth1) entered disabled state
[   75.179102] device eth1 entered promiscuous mode
[   75.411473] eth1: link up (1000Mbps/Full duplex)
[   75.826664] br-lan: port 1(eth1) entered blocking state
[   75.889375] br-lan: port 1(eth1) entered forwarding state
[   86.596690] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
[   86.709813] IPv6: ADDRCONF(NETDEV_UP): wwan0: link is not ready
[   86.831160] br-lan: port 2(wlan0) entered blocking state
[   86.894973] br-lan: port 2(wlan0) entered disabled state
[   86.963349] device wlan0 entered promiscuous mode
[   87.077397] br-lan: port 3(wlan1) entered blocking state
[   87.141209] br-lan: port 3(wlan1) entered disabled state
[   87.205244] device wlan1 entered promiscuous mode
[   88.723476] br-lan: port 2(wlan0) entered blocking state
[   88.787274] br-lan: port 2(wlan0) entered forwarding state
[   89.967545] br-lan: port 3(wlan1) entered blocking state
[   90.031293] br-lan: port 3(wlan1) entered forwarding state
System Log (part 1)
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    0.000000] Linux version 4.14.241 (glinet@glinet) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11257-5090152ae3)) #0 Thu Jul 29 19:50:28 2021
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] bootconsole [early0] enabled
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] CPU0 revision is: 00019374 (MIPS 24Kc)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] MIPS: machine is GL.iNet GL-X750 (NOR)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] SoC: Qualcomm Atheros QCA9533 ver 2 rev 0
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] Determined physical RAM map:
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000]  memory: 08000000 @ 00000000 (usable)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] Initrd not found or empty - disabling initrd
Thu Jul 20 14:25:14 2023 kern.warn kernel: [    0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Thu Jul 20 14:25:14 2023 kern.warn kernel: [    0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] Zone ranges:
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000]   Normal   [mem 0x0000000000000000-0x0000000007ffffff]
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] Movable zone start for each node
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] Early memory node ranges
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000]   node   0: [mem 0x0000000000000000-0x0000000007ffffff]
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
Thu Jul 20 14:25:14 2023 kern.debug kernel: [    0.000000] On node 0 totalpages: 32768
Thu Jul 20 14:25:14 2023 kern.debug kernel: [    0.000000] free_area_init_node: node 0, pgdat 805d7aa0, node_mem_map 81007ec0
Thu Jul 20 14:25:14 2023 kern.debug kernel: [    0.000000]   Normal zone: 256 pages used for memmap
Thu Jul 20 14:25:14 2023 kern.debug kernel: [    0.000000]   Normal zone: 0 pages reserved
Thu Jul 20 14:25:14 2023 kern.debug kernel: [    0.000000]   Normal zone: 32768 pages, LIFO batch:7
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    0.000000] random: get_random_bytes called from start_kernel+0x98/0x494 with crng_init=0
Thu Jul 20 14:25:14 2023 kern.debug kernel: [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Thu Jul 20 14:25:14 2023 kern.debug kernel: [    0.000000] pcpu-alloc: [0] 0
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 32512
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    0.000000] Kernel command line: rootfstype=squashfs,jffs2 rootfstype=squashfs,jffs2
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] Writing ErrCtl register=00000000
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] Readback ErrCtl register=00000000
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] Memory: 122404K/131072K available (4427K kernel code, 156K rwdata, 1008K rodata, 1244K init, 218K bss, 8668K reserved, 0K cma-reserved)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] NR_IRQS: 51
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] CPU clock: 650.000 MHz
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 5880801374 ns
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.000009] sched_clock: 32 bits at 325MHz, resolution 3ns, wraps every 6607641598ns
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.008250] Calibrating delay loop... 432.53 BogoMIPS (lpj=2162688)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.074862] pid_max: default: 32768 minimum: 301
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.079929] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.086902] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.098531] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.108950] futex hash table entries: 256 (order: -1, 3072 bytes)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.115476] pinctrl core: initialized pinctrl subsystem
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.122131] NET: Registered protocol family 16
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.133494] PCI host bridge /ahb/pcie-controller@180c0000 ranges:
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.139929]  MEM 0x0000000010000000..0x0000000013ffffff
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.145477]   IO 0x0000000000000000..0x0000000000000000
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.166845] PCI host bridge to bus 0000:00
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.171172] pci_bus 0000:00: root bus resource [mem 0x10000000-0x13ffffff]
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.178461] pci_bus 0000:00: root bus resource [io  0x0000]
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.184334] pci_bus 0000:00: root bus resource [??? 0x00000000 flags 0x0]
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.191489] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
Thu Jul 20 14:25:14 2023 kern.debug kernel: [    0.199863] pci 0000:00:00.0: [168c:0050] type 00 class 0x028000
Thu Jul 20 14:25:14 2023 kern.debug kernel: [    0.199922] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
Thu Jul 20 14:25:14 2023 kern.debug kernel: [    0.199976] pci 0000:00:00.0: reg 0x30: [mem 0x00000000-0x0000ffff pref]
Thu Jul 20 14:25:14 2023 kern.debug kernel: [    0.200053] pci 0000:00:00.0: supports D1
Thu Jul 20 14:25:14 2023 kern.debug kernel: [    0.200063] pci 0000:00:00.0: PME# supported from D0 D1 D3hot
Thu Jul 20 14:25:14 2023 kern.debug kernel: [    0.200268] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 00
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.200295] pci 0000:00:00.0: BAR 0: assigned [mem 0x10000000-0x101fffff 64bit]
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.208049] pci 0000:00:00.0: BAR 6: assigned [mem 0x10200000-0x1020ffff pref]
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.218207] clocksource: Switched to clocksource MIPS
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.224518] NET: Registered protocol family 2
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.229358] IP idents hash table entries: 2048 (order: 2, 16384 bytes)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.236879] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.244283] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.251002] TCP: Hash tables configured (established 1024 bind 1024)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.257846] UDP hash table entries: 256 (order: 0, 4096 bytes)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.264055] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.270933] NET: Registered protocol family 1
Thu Jul 20 14:25:14 2023 kern.debug kernel: [    0.275565] PCI: CLS 0 bytes, default 32
Thu Jul 20 14:25:14 2023 kern.warn kernel: [    0.278416] Crashlog allocated RAM at address 0x3f00000
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.285148] workingset: timestamp_bits=30 max_order=15 bucket_order=0
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.296891] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.303087] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.323471] io scheduler noop registered
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.327609] io scheduler deadline registered (default)
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.335172] pinctrl-single 1804002c.pinmux: 576 pins at pa b804002c size 72
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.343190] gpio-export gpio-export: 3 gpio(s) exported
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.349443] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.358443] console [ttyS0] disabled
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.362249] 18020000.uart: ttyS0 at MMIO 0x18020000 (irq = 9, base_baud = 1562500) is a 16550A
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.371366] console [ttyS0] enabled
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.454887] bootconsole [early0] disabled
Thu Jul 20 14:25:14 2023 kern.info kernel: [    0.568436] m25p80 spi0.0: w25q128 (16384 Kbytes)
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    0.624874] 4 fixed-partitions partitions found on MTD device spi0.0
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    0.701084] Creating 4 MTD partitions on "spi0.0":
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    0.758576] 0x000000000000-0x000000040000 : "u-boot"
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    0.818921] 0x000000040000-0x000000050000 : "u-boot-env"
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    0.883407] 0x000000050000-0x000000060000 : "art"
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    0.940635] 0x000000060000-0x000001000000 : "firmware"
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    1.005466] 2 uimage-fw partitions found on MTD device firmware
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    1.076577] Creating 2 MTD partitions on "firmware":
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    1.136118] 0x000000000000-0x0000001d0000 : "kernel"
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    1.196368] 0x0000001d0000-0x000000fa0000 : "rootfs"
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    1.256682] mtd: device 5 (rootfs) set to be root filesystem
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    1.325949] 1 squashfs-split partitions found on MTD device rootfs
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    1.400184] 0x000000c80000-0x000000fa0000 : "rootfs_data"
Thu Jul 20 14:25:14 2023 kern.err kernel: [    1.466674] spi-nand: unknown raw ID 00000000
Thu Jul 20 14:25:14 2023 kern.err kernel: [    1.518996] spi-nand: Failed to detect a SPI NAND (err = -19).
Thu Jul 20 14:25:14 2023 kern.info kernel: [    1.589576] libphy: Fixed MDIO Bus: probed
Thu Jul 20 14:25:14 2023 kern.err kernel: [    1.979310] ag71xx 19000000.eth: Could not connect to PHY device. Deferring probe.
Thu Jul 20 14:25:14 2023 kern.info kernel: [    2.748585] libphy: ag71xx_mdio: probed
Thu Jul 20 14:25:14 2023 kern.info kernel: [    3.078678] mdio-bus.0:1f: Found an AR934X built-in switch
Thu Jul 20 14:25:14 2023 kern.info kernel: [    3.144638] libphy: ar7240sw_mdio: probed
Thu Jul 20 14:25:14 2023 kern.info kernel: [    3.245784] ag71xx 1a000000.eth: connected to PHY at fixed-0:00 [uid=00000000, driver=Generic PHY]
Thu Jul 20 14:25:14 2023 kern.info kernel: [    3.353955] eth1: Atheros AG71xx at 0xba000000, irq 5, mode: gmii
Thu Jul 20 14:25:14 2023 kern.info kernel: [    3.429218] NET: Registered protocol family 10
Thu Jul 20 14:25:14 2023 kern.info kernel: [    3.487097] Segment Routing with IPv6
Thu Jul 20 14:25:14 2023 kern.info kernel: [    3.531115] NET: Registered protocol family 17
Thu Jul 20 14:25:14 2023 kern.info kernel: [    3.584443] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
Thu Jul 20 14:25:14 2023 kern.info kernel: [    3.739937] 8021q: 802.1Q VLAN Support v1.8
Thu Jul 20 14:25:14 2023 kern.info kernel: [    4.130399] ag71xx 19000000.eth: connected to PHY at mdio-bus.0:1f:04 [uid=004dd042, driver=Generic PHY]
Thu Jul 20 14:25:14 2023 kern.info kernel: [    4.245046] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode: mii
Thu Jul 20 14:25:14 2023 kern.info kernel: [    4.327381] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
Thu Jul 20 14:25:14 2023 kern.info kernel: [    4.418737] Freeing unused kernel memory: 1244K
Thu Jul 20 14:25:14 2023 kern.warn kernel: [    4.473101] This architecture does not have kernel memory protection.
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    4.618217] random: fast init done
Thu Jul 20 14:25:14 2023 user.info kernel: [    5.559941] init: Console is alive
Thu Jul 20 14:25:14 2023 user.info kernel: [    5.600964] init: - watchdog -
Thu Jul 20 14:25:14 2023 user.info kernel: [    8.976190] kmodloader: loading kernel modules from /etc/modules-boot.d/*
Thu Jul 20 14:25:14 2023 kern.info kernel: [    9.453687] usbcore: registered new interface driver usbfs
Thu Jul 20 14:25:14 2023 kern.info kernel: [    9.519582] usbcore: registered new interface driver hub
Thu Jul 20 14:25:14 2023 kern.info kernel: [    9.583401] usbcore: registered new device driver usb
Thu Jul 20 14:25:14 2023 kern.info kernel: [    9.653845] exFAT: Version 1.2.9
Thu Jul 20 14:25:14 2023 kern.info kernel: [    9.729156] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Thu Jul 20 14:25:14 2023 kern.notice kernel: [    9.816803] SCSI subsystem initialized
Thu Jul 20 14:25:14 2023 kern.info kernel: [    9.867375] ehci-platform: EHCI generic platform driver
Thu Jul 20 14:25:14 2023 kern.info kernel: [    9.930361] ehci-platform 1b000000.usb: EHCI Host Controller
Thu Jul 20 14:25:14 2023 kern.info kernel: [    9.998358] ehci-platform 1b000000.usb: new USB bus registered, assigned bus number 1
Thu Jul 20 14:25:14 2023 kern.info kernel: [   10.092394] ehci-platform 1b000000.usb: irq 3, io mem 0x1b000000
Thu Jul 20 14:25:14 2023 kern.info kernel: [   10.188253] ehci-platform 1b000000.usb: USB 2.0 started, EHCI 1.00
Thu Jul 20 14:25:14 2023 kern.info kernel: [   10.263289] hub 1-0:1.0: USB hub found
Thu Jul 20 14:25:14 2023 kern.info kernel: [   10.308686] hub 1-0:1.0: 1 port detected
Thu Jul 20 14:25:14 2023 kern.info kernel: [   10.359875] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Thu Jul 20 14:25:14 2023 kern.info kernel: [   10.435862] ohci-platform: OHCI generic platform driver
Thu Jul 20 14:25:14 2023 kern.info kernel: [   10.501536] uhci_hcd: USB Universal Host Controller Interface driver
Thu Jul 20 14:25:14 2023 kern.info kernel: [   10.582698] usbcore: registered new interface driver usb-storage
Thu Jul 20 14:25:14 2023 kern.info kernel: [   10.657444] usbcore: registered new interface driver uas
Thu Jul 20 14:25:14 2023 user.info kernel: [   10.722074] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Thu Jul 20 14:25:14 2023 kern.info kernel: [   10.808889] usb 1-1: new high-speed USB device number 2 using ehci-platform
Thu Jul 20 14:25:14 2023 user.info kernel: [   10.902939] init: - preinit -
Thu Jul 20 14:25:14 2023 kern.info kernel: [   11.092358] hub 1-1:1.0: USB hub found
Thu Jul 20 14:25:14 2023 kern.info kernel: [   11.288929] hub 1-1:1.0: 4 ports detected
Thu Jul 20 14:25:14 2023 kern.info kernel: [   11.738479] usb 1-1.1: new high-speed USB device number 3 using ehci-platform
Thu Jul 20 14:25:14 2023 kern.notice kernel: [   12.134094] random: procd: uninitialized urandom read (4 bytes read)
Thu Jul 20 14:25:14 2023 kern.info kernel: [   12.210908] usb-storage 1-1.1:1.0: USB Mass Storage device detected
Thu Jul 20 14:25:14 2023 kern.info kernel: [   12.368591] scsi host0: usb-storage 1-1.1:1.0
Thu Jul 20 14:25:14 2023 kern.info kernel: [   12.585437] usb 1-1.2: new high-speed USB device number 4 using ehci-platform
Thu Jul 20 14:25:14 2023 kern.notice kernel: [   12.676486] random: jshn: uninitialized urandom read (4 bytes read)
Thu Jul 20 14:25:14 2023 kern.notice kernel: [   12.971993] random: jshn: uninitialized urandom read (4 bytes read)
Thu Jul 20 14:25:14 2023 kern.warn kernel: [   13.164430] urandom_read: 1 callbacks suppressed
Thu Jul 20 14:25:14 2023 kern.notice kernel: [   13.164438] random: jshn: uninitialized urandom read (4 bytes read)
Thu Jul 20 14:25:14 2023 kern.notice kernel: [   13.340448] random: jshn: uninitialized urandom read (4 bytes read)
Thu Jul 20 14:25:14 2023 kern.notice kernel: [   13.466960] random: jshn: uninitialized urandom read (4 bytes read)
Thu Jul 20 14:25:14 2023 kern.notice kernel: [   13.548585] scsi 0:0:0:0: Direct-Access     Generic  STORAGE DEVICE   0233 PQ: 0 ANSI: 0
Thu Jul 20 14:25:14 2023 kern.info kernel: [   14.339259] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Thu Jul 20 14:25:14 2023 kern.notice kernel: [   14.669352] sd 0:0:0:0: [sda] Attached SCSI removable disk
Thu Jul 20 14:25:14 2023 kern.info kernel: [   15.469410] eth1: link up (1000Mbps/Full duplex)
Thu Jul 20 14:25:14 2023 kern.info kernel: [   15.526887] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
Thu Jul 20 14:25:14 2023 user.info kernel: [   17.791199] mount_root: loading kmods from internal overlay
Thu Jul 20 14:25:14 2023 user.info kernel: [   17.937581] kmodloader: loading kernel modules from //etc/modules-boot.d/*
Thu Jul 20 14:25:14 2023 user.info kernel: [   18.024963] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
Thu Jul 20 14:25:14 2023 kern.notice kernel: [   21.171494] jffs2: notice: (501) jffs2_build_xattr_subsystem: complete building xattr subsystem, 20 of xdatum (3 unchecked, 17 orphan) and 59 of xref (17 dead, 0 orphan) found.
Thu Jul 20 14:25:14 2023 user.info kernel: [   21.361171] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
Thu Jul 20 14:25:14 2023 user.info kernel: [   21.460126] block: extroot: not configured
Thu Jul 20 14:25:14 2023 kern.notice kernel: [   21.652719] jffs2: notice: (499) jffs2_build_xattr_subsystem: complete building xattr subsystem, 20 of xdatum (3 unchecked, 17 orphan) and 59 of xref (17 dead, 0 orphan) found.
Thu Jul 20 14:25:14 2023 user.info kernel: [   21.843836] mount_root: loading kmods from internal overlay
Thu Jul 20 14:25:14 2023 user.info kernel: [   21.985344] kmodloader: loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
Thu Jul 20 14:25:14 2023 user.info kernel: [   22.090834] kmodloader: done loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
Thu Jul 20 14:25:14 2023 user.info kernel: [   24.378681] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
Thu Jul 20 14:25:14 2023 user.info kernel: [   24.471712] block: extroot: not configured
Thu Jul 20 14:25:14 2023 user.info kernel: [   24.522332] mount_root: switching to jffs2 overlay
Thu Jul 20 14:25:14 2023 kern.warn kernel: [   24.654164] overlayfs: upper fs does not support tmpfile.
Thu Jul 20 14:25:14 2023 user.warn kernel: [   24.724779] urandom-seed: Seeding with /etc/urandom.seed
Thu Jul 20 14:25:14 2023 kern.info kernel: [   24.900074] eth1: link down
Thu Jul 20 14:25:14 2023 user.info kernel: [   24.951545] procd: - early -
Thu Jul 20 14:25:14 2023 user.info kernel: [   24.988053] procd: - watchdog -
Thu Jul 20 14:25:14 2023 kern.warn kernel: [   25.673449] urandom_read: 1 callbacks suppressed
Thu Jul 20 14:25:14 2023 kern.notice kernel: [   25.673457] random: jshn: uninitialized urandom read (4 bytes read)
Thu Jul 20 14:25:14 2023 user.info kernel: [   25.805402] procd: - watchdog -
Thu Jul 20 14:25:14 2023 user.info kernel: [   25.843440] procd: - ubus -
Thu Jul 20 14:25:14 2023 kern.notice kernel: [   26.174399] random: ubusd: uninitialized urandom read (4 bytes read)
Thu Jul 20 14:25:14 2023 user.info kernel: [   26.255589] procd: - init -
Thu Jul 20 14:25:14 2023 user.info kernel: [   31.044220] kmodloader: loading kernel modules from /etc/modules.d/*
Thu Jul 20 14:25:14 2023 user.info kernel: [   31.245364] urngd: v1.0.2 started.
Thu Jul 20 14:25:14 2023 kern.info kernel: [   31.653124] ntfs: driver 2.1.32 [Flags: R/O MODULE].
Thu Jul 20 14:25:14 2023 kern.info kernel: [   31.789077] tun: Universal TUN/TAP device driver, 1.6
Thu Jul 20 14:25:14 2023 kern.notice kernel: [   31.852580] random: crng init done
Thu Jul 20 14:25:14 2023 kern.info kernel: [   31.948916] GobiNet: 2018-12-21/SWI_2.55
Thu Jul 20 14:25:14 2023 kern.info kernel: [   31.997509] usbcore: registered new interface driver GobiNet
Thu Jul 20 14:25:14 2023 kern.info kernel: [   32.192098] usbcore: registered new interface driver usbserial
Thu Jul 20 14:25:14 2023 kern.info kernel: [   32.262226] usbcore: registered new interface driver usbserial_generic
Thu Jul 20 14:25:14 2023 kern.info kernel: [   32.340597] usbserial: USB Serial support registered for generic
Thu Jul 20 14:25:14 2023 kern.info kernel: [   32.639568] usbcore: registered new interface driver GobiSerial
Thu Jul 20 14:25:14 2023 kern.info kernel: [   32.710767] usbserial: USB Serial support registered for GobiSerial
Thu Jul 20 14:25:14 2023 kern.info kernel: [   32.786007] GobiSerial: 2015-08-27/SWI_2.25:GobiSerial
Thu Jul 20 14:25:14 2023 kern.info kernel: [   33.200151] ip6_tables: (C) 2000-2006 Netfilter Core Team
Thu Jul 20 14:25:14 2023 kern.info kernel: [   33.347258] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
Thu Jul 20 14:25:14 2023 kern.info kernel: [   33.687202] Netfilter messages via NETLINK v0.30.
Thu Jul 20 14:25:14 2023 kern.info kernel: [   33.801243] ip_set: protocol 6
Thu Jul 20 14:25:14 2023 kern.info kernel: [   33.953805] Mirror/redirect action on
Thu Jul 20 14:25:14 2023 kern.info kernel: [   34.069676] u32 classifier
Thu Jul 20 14:25:14 2023 kern.info kernel: [   34.102216]     input device check on
Thu Jul 20 14:25:14 2023 kern.info kernel: [   34.146076]     Actions configured
Thu Jul 20 14:25:14 2023 kern.info kernel: [   34.376681] GACT probability on
Thu Jul 20 14:25:14 2023 kern.info kernel: [   34.422697] Simple TC action Loaded
Thu Jul 20 14:25:14 2023 kern.info kernel: [   34.500692] fuse init (API version 7.26)
Thu Jul 20 14:25:14 2023 kern.info kernel: [   34.559865] usbcore: registered new interface driver cdc_acm
Thu Jul 20 14:25:14 2023 kern.info kernel: [   34.627786] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Thu Jul 20 14:25:14 2023 kern.info kernel: [   34.727397] usbcore: registered new interface driver cdc_ether
Thu Jul 20 14:25:14 2023 kern.info kernel: [   34.802416] usbcore: registered new interface driver cdc_ncm
Thu Jul 20 14:25:14 2023 kern.info kernel: [   34.876880] usbcore: registered new interface driver cdc_wdm
Thu Jul 20 14:25:14 2023 kern.info kernel: [   34.947842] Loading modules backported from Linux version v4.19.193-0-g1722257b8ece
Thu Jul 20 14:25:14 2023 kern.info kernel: [   35.039872] Backport generated by backports.git v4.19.193-1-0-gaa2cc8ea
Thu Jul 20 14:25:14 2023 kern.info kernel: [   35.122706] usbcore: registered new interface driver cp210x
Thu Jul 20 14:25:14 2023 kern.info kernel: [   35.189742] usbserial: USB Serial support registered for cp210x
Thu Jul 20 14:25:14 2023 kern.info kernel: [   35.278128] Ebtables v2.0 registered
Thu Jul 20 14:25:14 2023 kern.info kernel: [   35.323158] usbcore: registered new interface driver huawei_cdc_ncm
Thu Jul 20 14:25:14 2023 kern.info kernel: [   35.402578] ip_tables: (C) 2000-2006 Netfilter Core Team
Thu Jul 20 14:25:14 2023 kern.info kernel: [   35.469339] usbcore: registered new interface driver ipheth
Thu Jul 20 14:25:14 2023 kern.info kernel: [   35.735015] ctnetlink v0.93: registering with nfnetlink.
Thu Jul 20 14:25:14 2023 kern.info kernel: [   35.956770] qmi_wwan 1-1.2:1.4: cdc-wdm0: USB WDM device
Thu Jul 20 14:25:14 2023 kern.info kernel: [   36.020579] qmi_wwan 1-1.2:1.4: QuectelEC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
Thu Jul 20 14:25:14 2023 kern.info kernel: [   36.134488] qmi_wwan 1-1.2:1.4 wwan0: register 'qmi_wwan' at usb-1b000000.usb-1.2, WWAN/QMI device, 1a:01:86:86:b0:f1
Thu Jul 20 14:25:14 2023 kern.info kernel: [   36.262206] usbcore: registered new interface driver qmi_wwan
Thu Jul 20 14:25:14 2023 kern.info kernel: [   36.340235] usbcore: registered new interface driver rndis_host
Thu Jul 20 14:25:14 2023 kern.info kernel: [   36.415127] usbcore: registered new interface driver sierra
Thu Jul 20 14:25:14 2023 kern.info kernel: [   36.482162] usbserial: USB Serial support registered for Sierra USB modem
Thu Jul 20 14:25:14 2023 kern.info kernel: [   36.568736] usbcore: registered new interface driver sierra_net
Thu Jul 20 14:25:14 2023 kern.info kernel: [   36.656960] wireguard: WireGuard 1.0.20200611 loaded. See www.wireguard.com for information.
Thu Jul 20 14:25:14 2023 kern.info kernel: [   36.758348] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
Thu Jul 20 14:25:14 2023 kern.info kernel: [   36.928751] xt_time: kernel timezone is -0000
Thu Jul 20 14:25:14 2023 kern.info kernel: [   37.281665] usbcore: registered new interface driver option
Thu Jul 20 14:25:14 2023 kern.info kernel: [   37.348631] usbserial: USB Serial support registered for GSM modem (1-port)
Thu Jul 20 14:25:14 2023 kern.info kernel: [   37.432666] option 1-1.2:1.0: GSM modem (1-port) converter detected
Thu Jul 20 14:25:14 2023 kern.info kernel: [   37.508177] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB0
Thu Jul 20 14:25:14 2023 kern.info kernel: [   37.591865] option 1-1.2:1.1: GSM modem (1-port) converter detected
Thu Jul 20 14:25:14 2023 kern.info kernel: [   37.667401] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB1
Thu Jul 20 14:25:14 2023 kern.info kernel: [   37.751169] option 1-1.2:1.2: GSM modem (1-port) converter detected
Thu Jul 20 14:25:14 2023 kern.info kernel: [   37.826699] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
Thu Jul 20 14:25:14 2023 kern.info kernel: [   37.910466] option 1-1.2:1.3: GSM modem (1-port) converter detected
Thu Jul 20 14:25:14 2023 kern.info kernel: [   37.986027] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB3
Thu Jul 20 14:25:14 2023 kern.info kernel: [   38.352198] PPP generic driver version 2.4.2
Thu Jul 20 14:25:14 2023 kern.info kernel: [   38.406641] PPP MPPE Compression module registered
Thu Jul 20 14:25:14 2023 kern.info kernel: [   38.466623] NET: Registered protocol family 24
Thu Jul 20 14:25:14 2023 kern.warn kernel: [   38.579861] PCI: Enabling device 0000:00:00.0 (0000 -> 0002)
Thu Jul 20 14:25:14 2023 kern.info kernel: [   38.650143] ath10k_pci 0000:00:00.0: pci irq legacy oper_irq_mode 1 irq_mode 0 reset_mode 0
Thu Jul 20 14:25:14 2023 kern.warn kernel: [   39.022814] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/pre-cal-pci-0000:00:00.0.bin failed with error -2
Thu Jul 20 14:25:14 2023 kern.warn kernel: [   39.151331] ath10k_pci 0000:00:00.0: Falling back to user helper
Thu Jul 20 14:25:14 2023 kern.err kernel: [   52.903613] firmware ath10k!pre-cal-pci-0000:00:00.0.bin: firmware_loading_store: map pages failed
Thu Jul 20 14:25:14 2023 kern.warn kernel: [   53.018609] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9887/hw1.0/firmware-6.bin failed with error -2
Thu Jul 20 14:25:14 2023 kern.warn kernel: [   53.147067] ath10k_pci 0000:00:00.0: Falling back to user helper
Thu Jul 20 14:25:14 2023 kern.err kernel: [   53.428034] firmware ath10k!QCA9887!hw1.0!firmware-6.bin: firmware_loading_store: map pages failed
Thu Jul 20 14:25:14 2023 kern.info kernel: [   53.773675] ath10k_pci 0000:00:00.0: qca9887 hw1.0 target 0x4100016d chip_id 0x004000ff sub 0000:0000
Thu Jul 20 14:25:14 2023 kern.info kernel: [   53.884432] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 1
Thu Jul 20 14:25:14 2023 kern.info kernel: [   53.988056] ath10k_pci 0000:00:00.0: firmware ver 10.2.4-1.0-00047 api 5 features no-p2p,ignore-otp,skip-clock-init,mfp,allows-mesh-bcast crc32 62f7565f
Thu Jul 20 14:25:14 2023 kern.warn kernel: [   54.184722] ath10k_pci 0000:00:00.0: Direct firmware load for ath10k/QCA9887/hw1.0/board-2.bin failed with error -2
Thu Jul 20 14:25:14 2023 kern.warn kernel: [   54.310011] ath10k_pci 0000:00:00.0: Falling back to user helper
Thu Jul 20 14:25:14 2023 kern.err kernel: [   54.488644] firmware ath10k!QCA9887!hw1.0!board-2.bin: firmware_loading_store: map pages failed
Thu Jul 20 14:25:14 2023 kern.info kernel: [   54.609808] ath10k_pci 0000:00:00.0: board_file api 1 bmi_id N/A crc32 546cca0d
Thu Jul 20 14:25:14 2023 kern.info kernel: [   55.793437] ath10k_pci 0000:00:00.0: htt-ver 2.1 wmi-op 5 htt-op 2 cal file max-sta 128 raw 0 hwcrypto 1
Thu Jul 20 14:25:14 2023 kern.debug kernel: [   56.039703] ath: EEPROM regdomain: 0x0
Thu Jul 20 14:25:14 2023 kern.debug kernel: [   56.039711] ath: EEPROM indicates default country code should be used
Thu Jul 20 14:25:14 2023 kern.debug kernel: [   56.039714] ath: doing EEPROM country->regdmn map search
Thu Jul 20 14:25:14 2023 kern.debug kernel: [   56.039727] ath: country maps to regdmn code: 0x3a
Thu Jul 20 14:25:14 2023 kern.debug kernel: [   56.039732] ath: Country alpha2 being used: US
Thu Jul 20 14:25:14 2023 kern.debug kernel: [   56.039736] ath: Regpair used: 0x3a
Thu Jul 20 14:25:14 2023 kern.info kernel: [   56.181199] usbcore: registered new interface driver rt2800usb
Thu Jul 20 14:25:14 2023 kern.debug kernel: [   56.391039] ath: EEPROM regdomain: 0x0
Thu Jul 20 14:25:14 2023 kern.debug kernel: [   56.391049] ath: EEPROM indicates default country code should be used
Thu Jul 20 14:25:14 2023 kern.debug kernel: [   56.391052] ath: doing EEPROM country->regdmn map search
Thu Jul 20 14:25:14 2023 kern.debug kernel: [   56.391066] ath: country maps to regdmn code: 0x3a
Thu Jul 20 14:25:14 2023 kern.debug kernel: [   56.391071] ath: Country alpha2 being used: US
Thu Jul 20 14:25:14 2023 kern.debug kernel: [   56.391074] ath: Regpair used: 0x3a
Thu Jul 20 14:25:14 2023 kern.debug kernel: [   56.404868] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
Thu Jul 20 14:25:14 2023 kern.info kernel: [   56.406574] ieee80211 phy1: Atheros AR9531 Rev:2 mem=0xb8100000, irq=13
Thu Jul 20 14:25:14 2023 user.info kernel: [   56.578866] kmodloader: done loading kernel modules from /etc/modules.d/*
Thu Jul 20 14:25:16 2023 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Thu Jul 20 14:25:16 2023 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Thu Jul 20 14:25:16 2023 daemon.info dnsmasq[1854]: started, version 2.80 cachesize 150
Thu Jul 20 14:25:16 2023 daemon.info dnsmasq[1854]: DNS service limited to local subnets
Thu Jul 20 14:25:16 2023 daemon.info dnsmasq[1854]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth nettlehash DNSSEC no-ID loop-detect inotify dumpfile
Part 2
Thu Jul 20 14:25:16 2023 daemon.info dnsmasq[1854]: using local addresses only for domain test
Thu Jul 20 14:25:16 2023 daemon.info dnsmasq[1854]: using local addresses only for domain onion
Thu Jul 20 14:25:16 2023 daemon.info dnsmasq[1854]: using local addresses only for domain localhost
Thu Jul 20 14:25:16 2023 daemon.info dnsmasq[1854]: using local addresses only for domain invalid
Thu Jul 20 14:25:16 2023 daemon.info dnsmasq[1854]: using local addresses only for domain bind
Thu Jul 20 14:25:16 2023 daemon.info dnsmasq[1854]: using nameserver 127.0.0.1#53535
Thu Jul 20 14:25:16 2023 daemon.info dnsmasq[1854]: using local addresses only for domain lan
Thu Jul 20 14:25:16 2023 daemon.info dnsmasq[1854]: read /etc/hosts - 4 addresses
Thu Jul 20 14:25:16 2023 daemon.info dnsmasq[1854]: read /tmp/hosts/dhcp.cfg01411c - 1 addresses
Thu Jul 20 14:25:17 2023 authpriv.info dropbear[1887]: Not backgrounding
Thu Jul 20 14:25:20 2023 user.notice : Added device handler type: 8021ad
Thu Jul 20 14:25:20 2023 user.notice : Added device handler type: 8021q
Thu Jul 20 14:25:20 2023 user.notice : Added device handler type: macvlan
Thu Jul 20 14:25:20 2023 user.notice : Added device handler type: veth
Thu Jul 20 14:25:20 2023 user.notice : Added device handler type: bridge
Thu Jul 20 14:25:20 2023 user.notice : Added device handler type: Network device
Thu Jul 20 14:25:20 2023 user.notice : Added device handler type: tunnel
Thu Jul 20 14:25:21 2023 daemon.notice procd: /etc/rc.d/S30gl_ssids: uci: Entry not found
Thu Jul 20 14:25:21 2023 daemon.notice procd: /etc/init.d/gl_ssids: uci: Entry not found
Thu Jul 20 14:25:22 2023 daemon.notice procd: /etc/rc.d/S36gl_route_policy: uci: Entry not found
Thu Jul 20 14:25:27 2023 kern.info kernel: [   72.743036] IPv6: ADDRCONF(NETDEV_UP): lo: link is not ready
Thu Jul 20 14:25:28 2023 kern.info kernel: [   73.734033] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
Thu Jul 20 14:25:29 2023 kern.info kernel: [   74.827294] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
Thu Jul 20 14:25:30 2023 kern.info kernel: [   75.053443] br-lan: port 1(eth1) entered blocking state
Thu Jul 20 14:25:30 2023 kern.info kernel: [   75.116151] br-lan: port 1(eth1) entered disabled state
Thu Jul 20 14:25:30 2023 kern.info kernel: [   75.179102] device eth1 entered promiscuous mode
Thu Jul 20 14:25:30 2023 kern.info kernel: [   75.411473] eth1: link up (1000Mbps/Full duplex)
Thu Jul 20 14:25:30 2023 kern.info kernel: [   75.826664] br-lan: port 1(eth1) entered blocking state
Thu Jul 20 14:25:30 2023 kern.info kernel: [   75.889375] br-lan: port 1(eth1) entered forwarding state
Thu Jul 20 14:25:31 2023 daemon.notice netifd: Interface 'lan' is enabled
Thu Jul 20 14:25:31 2023 daemon.notice netifd: Interface 'lan' is setting up now
Thu Jul 20 14:25:31 2023 daemon.notice netifd: Interface 'lan' is now up
Thu Jul 20 14:25:31 2023 daemon.notice netifd: Interface 'loopback' is enabled
Thu Jul 20 14:25:31 2023 daemon.notice netifd: Interface 'loopback' is setting up now
Thu Jul 20 14:25:31 2023 daemon.notice netifd: Interface 'loopback' is now up
Thu Jul 20 14:25:31 2023 daemon.notice netifd: Interface 'modem_1_1_2' is setting up now
Thu Jul 20 14:25:31 2023 daemon.notice netifd: Interface 'wan' is enabled
Thu Jul 20 14:25:31 2023 daemon.notice netifd: bridge 'br-lan' link is up
Thu Jul 20 14:25:31 2023 daemon.notice netifd: Interface 'lan' has link connectivity
Thu Jul 20 14:25:31 2023 daemon.notice netifd: Network device 'eth1' link is up
Thu Jul 20 14:25:31 2023 daemon.notice netifd: Network device 'lo' link is up
Thu Jul 20 14:25:31 2023 daemon.notice netifd: Interface 'loopback' has link connectivity
Thu Jul 20 14:25:33 2023 daemon.notice netifd: modem_1_1_2 (2298): Waiting for SIM initialization
Thu Jul 20 14:25:35 2023 daemon.notice netifd: modem_1_1_2 (2298): Waiting for network registration
Thu Jul 20 14:25:35 2023 daemon.notice netifd: modem_1_1_2 (2298): Starting network modem_1_1_2
Thu Jul 20 14:25:38 2023 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Thu Jul 20 14:25:38 2023 daemon.notice procd: /etc/rc.d/S70modem-init: thermal setting failed
Thu Jul 20 14:25:38 2023 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Thu Jul 20 14:25:40 2023 daemon.err hostapd: Configuration file: /var/run/hostapd-phy1.conf
Thu Jul 20 14:25:40 2023 daemon.info dnsmasq[1854]: exiting on receipt of SIGTERM
Thu Jul 20 14:25:40 2023 daemon.notice netifd: modem_1_1_2 (2298): Setting up wwan0
Thu Jul 20 14:25:41 2023 kern.warn kernel: [   86.596690] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Thu Jul 20 14:25:41 2023 daemon.info dnsmasq[2775]: started, version 2.80 cachesize 150
Thu Jul 20 14:25:41 2023 daemon.info dnsmasq[2775]: DNS service limited to local subnets
Thu Jul 20 14:25:41 2023 kern.info kernel: [   86.709813] IPv6: ADDRCONF(NETDEV_UP): wwan0: link is not ready
Thu Jul 20 14:25:41 2023 daemon.info dnsmasq[2775]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth nettlehash DNSSEC no-ID loop-detect inotify dumpfile
Thu Jul 20 14:25:41 2023 daemon.info dnsmasq-dhcp[2775]: DHCP, IP range 192.168.8.100 -- 192.168.8.249, lease time 12h
Thu Jul 20 14:25:41 2023 daemon.info dnsmasq[2775]: using local addresses only for domain test
Thu Jul 20 14:25:41 2023 daemon.info dnsmasq[2775]: using local addresses only for domain onion
Thu Jul 20 14:25:41 2023 daemon.info dnsmasq[2775]: using local addresses only for domain localhost
Thu Jul 20 14:25:41 2023 daemon.info dnsmasq[2775]: using local addresses only for domain invalid
Thu Jul 20 14:25:41 2023 daemon.info dnsmasq[2775]: using local addresses only for domain bind
Thu Jul 20 14:25:41 2023 daemon.info dnsmasq[2775]: using nameserver 127.0.0.1#53535
Thu Jul 20 14:25:41 2023 daemon.info dnsmasq[2775]: using local addresses only for domain lan
Thu Jul 20 14:25:41 2023 daemon.info dnsmasq[2775]: read /etc/hosts - 4 addresses
Thu Jul 20 14:25:41 2023 daemon.info dnsmasq[2775]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Thu Jul 20 14:25:41 2023 daemon.info dnsmasq-dhcp[2775]: read /etc/ethers - 0 addresses
Thu Jul 20 14:25:41 2023 kern.info kernel: [   86.831160] br-lan: port 2(wlan0) entered blocking state
Thu Jul 20 14:25:41 2023 kern.info kernel: [   86.894973] br-lan: port 2(wlan0) entered disabled state
Thu Jul 20 14:25:41 2023 kern.info kernel: [   86.963349] device wlan0 entered promiscuous mode
Thu Jul 20 14:25:42 2023 kern.info kernel: [   87.077397] br-lan: port 3(wlan1) entered blocking state
Thu Jul 20 14:25:42 2023 kern.info kernel: [   87.141209] br-lan: port 3(wlan1) entered disabled state
Thu Jul 20 14:25:42 2023 kern.info kernel: [   87.205244] device wlan1 entered promiscuous mode
Thu Jul 20 14:25:42 2023 daemon.notice netifd: Interface 'modem_1_1_2' is now up
Thu Jul 20 14:25:42 2023 daemon.notice netifd: radio0 (2299): sh: /usr/bin/ovs-vsctl: not found
Thu Jul 20 14:25:42 2023 daemon.notice netifd: radio1 (2300): sh: /usr/bin/ovs-vsctl: not found
Thu Jul 20 14:25:42 2023 daemon.notice netifd: Network device 'wwan0' link is up
Thu Jul 20 14:25:42 2023 daemon.notice netifd: Network alias 'wwan0' link is up
Thu Jul 20 14:25:42 2023 daemon.notice netifd: Interface 'modem_1_1_2_4' is enabled
Thu Jul 20 14:25:42 2023 daemon.notice netifd: Interface 'modem_1_1_2_4' has link connectivity
Thu Jul 20 14:25:42 2023 daemon.notice netifd: Interface 'modem_1_1_2_4' is setting up now
Thu Jul 20 14:25:42 2023 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->HT_SCAN
Thu Jul 20 14:25:42 2023 daemon.notice hostapd: wlan1: interface state UNINITIALIZED->HT_SCAN
Thu Jul 20 14:25:42 2023 daemon.notice netifd: modem_1_1_2_4 (2887): udhcpc: started, v1.30.1
Thu Jul 20 14:25:43 2023 daemon.err hostapd: Using interface wlan0 with hwaddr e4:95:6e:46:e0:67 and ssid "GL-X750-064-5G"
Thu Jul 20 14:25:43 2023 daemon.notice netifd: modem_1_1_2_4 (2887): udhcpc: sending discover
Thu Jul 20 14:25:43 2023 daemon.notice netifd: modem_1_1_2_4 (2887): udhcpc: sending select for 10.143.214.49
Thu Jul 20 14:25:43 2023 daemon.notice netifd: modem_1_1_2_4 (2887): udhcpc: lease of 10.143.214.49 obtained, lease time 7200
Thu Jul 20 14:25:43 2023 kern.info kernel: [   88.723476] br-lan: port 2(wlan0) entered blocking state
Thu Jul 20 14:25:43 2023 kern.info kernel: [   88.787274] br-lan: port 2(wlan0) entered forwarding state
Thu Jul 20 14:25:43 2023 daemon.notice hostapd: wlan0: interface state HT_SCAN->ENABLED
Thu Jul 20 14:25:43 2023 daemon.notice hostapd: wlan0: AP-ENABLED
Thu Jul 20 14:25:43 2023 daemon.notice procd: /etc/rc.d/S90vpn-service: cat: can't open '/etc/openvpn/ovpn/server.ovpn': No such file or directory
Thu Jul 20 14:25:44 2023 daemon.err hostapd: Using interface wlan1 with hwaddr e4:95:6e:46:e0:66 and ssid "GL-X750-064"
Thu Jul 20 14:25:44 2023 daemon.notice netifd: Network device 'wlan0' link is up
Thu Jul 20 14:25:44 2023 daemon.notice netifd: Interface 'modem_1_1_2_4' is now up
Thu Jul 20 14:25:44 2023 kern.info kernel: [   89.967545] br-lan: port 3(wlan1) entered blocking state
Thu Jul 20 14:25:44 2023 kern.info kernel: [   90.031293] br-lan: port 3(wlan1) entered forwarding state
Thu Jul 20 14:25:45 2023 daemon.notice hostapd: wlan1: interface state HT_SCAN->ENABLED
Thu Jul 20 14:25:45 2023 daemon.notice hostapd: wlan1: AP-ENABLED
Thu Jul 20 14:25:45 2023 daemon.notice procd: /etc/rc.d/S94smstools3: Creating minimum spool directories
Thu Jul 20 14:25:45 2023 daemon.notice netifd: Network device 'wlan1' link is up
Thu Jul 20 14:25:47 2023 daemon.info smsd[3080]: 2023-07-20 14:25:47,2, smsd: Smsd v3.1.21 started.
Thu Jul 20 14:25:47 2023 daemon.info smsd[3080]: 2023-07-20 14:25:47,2, smsd: Running as root:root (0:0).
Thu Jul 20 14:25:47 2023 daemon.info smsd[3080]: 2023-07-20 14:25:47,2, smsd: Running in terminal mode.
Thu Jul 20 14:25:47 2023 daemon.notice procd: /etc/rc.d/S95done: killall: uqmi: no process killed
Thu Jul 20 14:25:48 2023 daemon.err usbmuxd[3119]: [14:25:48.219][3] usbmuxd v1.1.1 starting up
Thu Jul 20 14:25:48 2023 daemon.err usbmuxd[3119]: [14:25:48.225][3] Using libusb 1.0.22
Thu Jul 20 14:25:48 2023 daemon.err usbmuxd[3119]: [14:25:48.244][3] Initialization complete
Thu Jul 20 14:25:48 2023 daemon.err usbmuxd[3119]: [14:25:48.245][3] Enabled exit on SIGUSR1 if no devices are attached. Start a new instance with "--exit" to trigger.
Thu Jul 20 14:25:48 2023 daemon.notice procd: /etc/rc.d/S96led: setting up led WAN
Thu Jul 20 14:25:48 2023 daemon.notice procd: /etc/rc.d/S96led: setting up led LTE
Thu Jul 20 14:25:49 2023 user.info mwan3rtmon[2669]: Detect rtchange event.
Thu Jul 20 14:25:51 2023 user.info : gl_health start->
Thu Jul 20 14:38:23 2023 daemon.notice procd: /etc/rc.d/S99lighttpd: sed: /etc/lighttpd/conf.d/10-port.conf: No such file or directory
Thu Jul 20 14:38:23 2023 daemon.notice procd: /etc/rc.d/S99lighttpd: netstat: showing only processes with your user ID
Thu Jul 20 14:38:28 2023 user.notice wireguard: wireguard client start
Thu Jul 20 14:38:29 2023 user.info mwan3rtmon[2669]: Detect rtchange event.
Thu Jul 20 14:38:29 2023 daemon.info procd: - init complete -
Thu Jul 20 14:38:30 2023 user.notice firewall: Reloading firewall due to ifup of modem_1_1_2 (wwan0)
Thu Jul 20 14:38:32 2023 user.info mwan3rtmon[2669]: Detect rtchange event.
Thu Jul 20 14:38:33 2023 user.notice firewall: Reloading firewall due to ifup of modem_1_1_2_4 (wwan0)
Thu Jul 20 14:38:46 2023 daemon.info hostapd: wlan0: STA 6c:7e:67:bc:88:ec IEEE 802.11: authenticated
Thu Jul 20 14:38:46 2023 daemon.info hostapd: wlan0: STA 6c:7e:67:bc:88:ec IEEE 802.11: associated (aid 1)
Thu Jul 20 14:38:46 2023 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 6c:7e:67:bc:88:ec
Thu Jul 20 14:38:46 2023 daemon.info hostapd: wlan0: STA 6c:7e:67:bc:88:ec RADIUS: starting accounting session 1B43CD55CEAF43C3
Thu Jul 20 14:38:46 2023 daemon.info hostapd: wlan0: STA 6c:7e:67:bc:88:ec WPA: pairwise key handshake completed (RSN)
Thu Jul 20 14:38:46 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.8.243 6c:7e:67:bc:88:ec
Thu Jul 20 14:38:46 2023 daemon.info dnsmasq-dhcp[2775]: DHCPACK(br-lan) 192.168.8.243 6c:7e:67:bc:88:ec M2011
Thu Jul 20 14:45:34 2023 daemon.info hostapd: wlan0: STA c8:2a:dd:95:d5:22 IEEE 802.11: authenticated
Thu Jul 20 14:45:34 2023 daemon.info hostapd: wlan0: STA c8:2a:dd:95:d5:22 IEEE 802.11: associated (aid 2)
Thu Jul 20 14:45:34 2023 daemon.notice hostapd: wlan0: AP-STA-CONNECTED c8:2a:dd:95:d5:22
Thu Jul 20 14:45:34 2023 daemon.info hostapd: wlan0: STA c8:2a:dd:95:d5:22 RADIUS: starting accounting session 711132A2CEB0FC37
Thu Jul 20 14:45:34 2023 daemon.info hostapd: wlan0: STA c8:2a:dd:95:d5:22 WPA: pairwise key handshake completed (RSN)
Thu Jul 20 14:45:34 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.8.155 c8:2a:dd:95:d5:22
Thu Jul 20 14:45:34 2023 daemon.info dnsmasq-dhcp[2775]: DHCPACK(br-lan) 192.168.8.155 c8:2a:dd:95:d5:22 Pixel-6a
Thu Jul 20 15:19:01 2023 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED c8:2a:dd:95:d5:22
Thu Jul 20 15:19:01 2023 daemon.info hostapd: wlan0: STA c8:2a:dd:95:d5:22 IEEE 802.11: disassociated
Thu Jul 20 15:19:02 2023 daemon.info hostapd: wlan0: STA c8:2a:dd:95:d5:22 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Thu Jul 20 15:23:03 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.8.243 6c:7e:67:bc:88:ec
Thu Jul 20 15:23:03 2023 daemon.info dnsmasq-dhcp[2775]: DHCPACK(br-lan) 192.168.8.243 6c:7e:67:bc:88:ec M2011
Thu Jul 20 15:24:51 2023 daemon.info hostapd: wlan0: STA c8:2a:dd:95:d5:22 IEEE 802.11: authenticated
Thu Jul 20 15:24:51 2023 daemon.info hostapd: wlan0: STA c8:2a:dd:95:d5:22 IEEE 802.11: associated (aid 2)
Thu Jul 20 15:24:51 2023 daemon.notice hostapd: wlan0: AP-STA-CONNECTED c8:2a:dd:95:d5:22
Thu Jul 20 15:24:51 2023 daemon.info hostapd: wlan0: STA c8:2a:dd:95:d5:22 RADIUS: starting accounting session CC4289316FD3FCC7
Thu Jul 20 15:24:51 2023 daemon.info hostapd: wlan0: STA c8:2a:dd:95:d5:22 WPA: pairwise key handshake completed (RSN)
Thu Jul 20 15:24:51 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.8.155 c8:2a:dd:95:d5:22
Thu Jul 20 15:24:51 2023 daemon.info dnsmasq-dhcp[2775]: DHCPACK(br-lan) 192.168.8.155 c8:2a:dd:95:d5:22 Pixel-6a
Thu Jul 20 15:30:20 2023 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED 6c:7e:67:bc:88:ec
Thu Jul 20 15:30:20 2023 daemon.info hostapd: wlan0: STA 6c:7e:67:bc:88:ec IEEE 802.11: disassociated due to inactivity
Thu Jul 20 15:30:21 2023 daemon.info hostapd: wlan0: STA 6c:7e:67:bc:88:ec IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Thu Jul 20 15:30:24 2023 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED c8:2a:dd:95:d5:22
Thu Jul 20 15:30:24 2023 daemon.info hostapd: wlan0: STA c8:2a:dd:95:d5:22 IEEE 802.11: disassociated due to inactivity
Thu Jul 20 15:30:25 2023 daemon.info hostapd: wlan0: STA c8:2a:dd:95:d5:22 IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Thu Jul 20 15:38:12 2023 daemon.notice netifd: modem_1_1_2_4 (2887): udhcpc: sending renew to 10.143.214.50
Thu Jul 20 15:38:12 2023 daemon.notice netifd: modem_1_1_2_4 (2887): udhcpc: lease of 10.143.214.49 obtained, lease time 7200
Thu Jul 20 16:13:24 2023 daemon.err gl_monitor[3532]: Error opening serial port  - No such file or directory(2).
Thu Jul 20 16:13:25 2023 daemon.err gl_monitor[3532]: Error opening serial port  - No such file or directory(2).
Thu Jul 20 16:13:25 2023 daemon.notice netifd: modem_1_1_2 (5292): Stopping network modem_1_1_2
Thu Jul 20 16:13:25 2023 daemon.notice netifd: modem_1_1_2_4 (2887): udhcpc: received SIGTERM
Thu Jul 20 16:13:25 2023 daemon.notice netifd: Interface 'modem_1_1_2_4' is now down
Thu Jul 20 16:13:25 2023 daemon.notice netifd: Network alias '' link is down
Thu Jul 20 16:13:25 2023 daemon.notice netifd: Interface 'modem_1_1_2_4' has link connectivity loss
Thu Jul 20 16:13:25 2023 daemon.notice netifd: Interface 'modem_1_1_2_4' is disabled
Thu Jul 20 16:13:25 2023 daemon.notice netifd: modem_1_1_2 (5292): Command failed: Permission denied
Thu Jul 20 16:13:25 2023 daemon.notice netifd: Interface 'modem_1_1_2' is now down
Thu Jul 20 16:13:26 2023 daemon.err gl_monitor[3532]: killall: uqmi: no process killed
Thu Jul 20 16:13:26 2023 daemon.notice netifd: Interface 'modem_1_1_2' is setting up now
Thu Jul 20 16:13:26 2023 user.notice root: modem_1_1_2 real ip miss
Thu Jul 20 16:13:28 2023 daemon.notice netifd: modem_1_1_2 (5399): Waiting for SIM initialization
Thu Jul 20 16:13:29 2023 daemon.notice netifd: modem_1_1_2 (5399): Waiting for network registration
Thu Jul 20 16:13:29 2023 daemon.notice netifd: modem_1_1_2 (5399): Starting network modem_1_1_2
Thu Jul 20 16:13:31 2023 daemon.notice netifd: modem_1_1_2 (5399): Setting up wwan0
Thu Jul 20 16:13:31 2023 daemon.notice netifd: Interface 'modem_1_1_2' is now up
Thu Jul 20 16:13:31 2023 daemon.notice netifd: Network device 'wwan0' link is up
Thu Jul 20 16:13:31 2023 daemon.notice netifd: Network alias 'wwan0' link is up
Thu Jul 20 16:13:31 2023 daemon.notice netifd: Interface 'modem_1_1_2_4' is enabled
Thu Jul 20 16:13:31 2023 daemon.notice netifd: Interface 'modem_1_1_2_4' has link connectivity
Thu Jul 20 16:13:31 2023 daemon.notice netifd: Interface 'modem_1_1_2_4' is setting up now
Thu Jul 20 16:13:31 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: started, v1.30.1
Thu Jul 20 16:13:31 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending discover
Thu Jul 20 16:13:31 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending select for 10.97.107.148
Thu Jul 20 16:13:31 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Thu Jul 20 16:13:32 2023 daemon.notice netifd: Interface 'modem_1_1_2_4' is now up
Thu Jul 20 16:13:35 2023 user.info mwan3rtmon[2669]: Detect rtchange event.
Thu Jul 20 16:13:36 2023 user.notice firewall: Reloading firewall due to ifup of modem_1_1_2 (wwan0)
Thu Jul 20 16:13:38 2023 user.info mwan3rtmon[2669]: Detect rtchange event.
Thu Jul 20 16:13:39 2023 user.notice firewall: Reloading firewall due to ifup of modem_1_1_2_4 (wwan0)
Thu Jul 20 17:13:31 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Thu Jul 20 17:13:31 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Thu Jul 20 18:13:31 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Thu Jul 20 18:13:31 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Thu Jul 20 19:13:31 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Thu Jul 20 19:13:31 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Thu Jul 20 19:57:18 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.8.208 ec:71:db:e6:b4:7c
Thu Jul 20 19:57:18 2023 daemon.info dnsmasq-dhcp[2775]: DHCPACK(br-lan) 192.168.8.208 ec:71:db:e6:b4:7c Shed
Thu Jul 20 19:57:18 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.8.201 ec:71:db:91:80:28
Thu Jul 20 19:57:18 2023 daemon.info dnsmasq-dhcp[2775]: DHCPACK(br-lan) 192.168.8.201 ec:71:db:91:80:28 Shed
Thu Jul 20 19:57:36 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.8.166 34:60:f9:b1:4d:33
Thu Jul 20 19:57:36 2023 daemon.info dnsmasq-dhcp[2775]: DHCPACK(br-lan) 192.168.8.166 34:60:f9:b1:4d:33 TL-SG108PE
Thu Jul 20 20:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Thu Jul 20 20:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Thu Jul 20 21:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Thu Jul 20 21:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Thu Jul 20 22:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Thu Jul 20 22:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Thu Jul 20 23:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Thu Jul 20 23:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Fri Jul 21 00:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Fri Jul 21 00:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Fri Jul 21 01:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Fri Jul 21 01:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Fri Jul 21 01:57:18 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.8.208 ec:71:db:e6:b4:7c
Fri Jul 21 01:57:18 2023 daemon.info dnsmasq-dhcp[2775]: DHCPACK(br-lan) 192.168.8.208 ec:71:db:e6:b4:7c Shed
Fri Jul 21 01:57:18 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.8.201 ec:71:db:91:80:28
Fri Jul 21 01:57:18 2023 daemon.info dnsmasq-dhcp[2775]: DHCPACK(br-lan) 192.168.8.201 ec:71:db:91:80:28 Shed
Fri Jul 21 01:57:53 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.8.166 34:60:f9:b1:4d:33
Fri Jul 21 01:57:53 2023 daemon.info dnsmasq-dhcp[2775]: DHCPACK(br-lan) 192.168.8.166 34:60:f9:b1:4d:33 TL-SG108PE
Fri Jul 21 02:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Fri Jul 21 02:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Fri Jul 21 03:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Fri Jul 21 03:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Fri Jul 21 04:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Fri Jul 21 04:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Fri Jul 21 05:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Fri Jul 21 05:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Fri Jul 21 06:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Fri Jul 21 06:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Fri Jul 21 07:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Fri Jul 21 07:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Fri Jul 21 07:57:18 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.8.208 ec:71:db:e6:b4:7c
Fri Jul 21 07:57:18 2023 daemon.info dnsmasq-dhcp[2775]: DHCPACK(br-lan) 192.168.8.208 ec:71:db:e6:b4:7c Shed
Fri Jul 21 07:57:18 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.8.201 ec:71:db:91:80:28
Fri Jul 21 07:57:18 2023 daemon.info dnsmasq-dhcp[2775]: DHCPACK(br-lan) 192.168.8.201 ec:71:db:91:80:28 Shed
Fri Jul 21 07:58:10 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.8.166 34:60:f9:b1:4d:33
Fri Jul 21 07:58:10 2023 daemon.info dnsmasq-dhcp[2775]: DHCPACK(br-lan) 192.168.8.166 34:60:f9:b1:4d:33 TL-SG108PE
Fri Jul 21 08:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Fri Jul 21 08:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Fri Jul 21 09:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Fri Jul 21 09:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Fri Jul 21 10:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: sending renew to 10.97.107.149
Fri Jul 21 10:13:32 2023 daemon.notice netifd: modem_1_1_2_4 (5780): udhcpc: lease of 10.97.107.148 obtained, lease time 7200
Fri Jul 21 10:31:46 2023 daemon.info hostapd: wlan0: STA c8:2a:dd:95:d5:22 IEEE 802.11: authenticated
Fri Jul 21 10:31:46 2023 daemon.info hostapd: wlan0: STA c8:2a:dd:95:d5:22 IEEE 802.11: associated (aid 1)
Fri Jul 21 10:31:46 2023 daemon.notice hostapd: wlan0: AP-STA-CONNECTED c8:2a:dd:95:d5:22
Fri Jul 21 10:31:46 2023 daemon.info hostapd: wlan0: STA c8:2a:dd:95:d5:22 RADIUS: starting accounting session 2E4FED6D6D7CE35A
Fri Jul 21 10:31:46 2023 daemon.info hostapd: wlan0: STA c8:2a:dd:95:d5:22 WPA: pairwise key handshake completed (RSN)
Fri Jul 21 10:32:22 2023 daemon.info dnsmasq-dhcp[2775]: DHCPDISCOVER(br-lan) c8:2a:dd:95:d5:22
Fri Jul 21 10:32:22 2023 daemon.info dnsmasq-dhcp[2775]: DHCPOFFER(br-lan) 192.168.8.155 c8:2a:dd:95:d5:22
Fri Jul 21 10:32:22 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.8.155 c8:2a:dd:95:d5:22
Fri Jul 21 10:32:22 2023 daemon.info dnsmasq-dhcp[2775]: DHCPACK(br-lan) 192.168.8.155 c8:2a:dd:95:d5:22 Pixel-6a
Fri Jul 21 10:47:26 2023 daemon.info hostapd: wlan0: STA 6c:7e:67:bc:88:ec IEEE 802.11: authenticated
Fri Jul 21 10:47:26 2023 daemon.info hostapd: wlan0: STA 6c:7e:67:bc:88:ec IEEE 802.11: associated (aid 2)
Fri Jul 21 10:47:26 2023 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 6c:7e:67:bc:88:ec
Fri Jul 21 10:47:26 2023 daemon.info hostapd: wlan0: STA 6c:7e:67:bc:88:ec RADIUS: starting accounting session 5DB3094EF1E27E18
Fri Jul 21 10:47:26 2023 daemon.info hostapd: wlan0: STA 6c:7e:67:bc:88:ec WPA: pairwise key handshake completed (RSN)
Fri Jul 21 10:47:26 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.1.168 6c:7e:67:bc:88:ec
Fri Jul 21 10:47:26 2023 daemon.info dnsmasq-dhcp[2775]: DHCPNAK(br-lan) 192.168.1.168 6c:7e:67:bc:88:ec wrong network
Fri Jul 21 10:47:27 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.1.168 6c:7e:67:bc:88:ec
Fri Jul 21 10:47:27 2023 daemon.info dnsmasq-dhcp[2775]: DHCPNAK(br-lan) 192.168.1.168 6c:7e:67:bc:88:ec wrong network
Fri Jul 21 10:47:30 2023 daemon.info dnsmasq-dhcp[2775]: DHCPDISCOVER(br-lan) 6c:7e:67:bc:88:ec
Fri Jul 21 10:47:30 2023 daemon.info dnsmasq-dhcp[2775]: DHCPOFFER(br-lan) 192.168.8.243 6c:7e:67:bc:88:ec
Fri Jul 21 10:50:29 2023 daemon.info dnsmasq-dhcp[2775]: DHCPDISCOVER(br-lan) 6c:7e:67:bc:88:ec
Fri Jul 21 10:50:29 2023 daemon.info dnsmasq-dhcp[2775]: DHCPOFFER(br-lan) 192.168.8.243 6c:7e:67:bc:88:ec
Fri Jul 21 10:50:30 2023 daemon.info dnsmasq-dhcp[2775]: DHCPREQUEST(br-lan) 192.168.8.243 6c:7e:67:bc:88:ec
Fri Jul 21 10:50:30 2023 daemon.info dnsmasq-dhcp[2775]: DHCPACK(br-lan) 192.168.8.243 6c:7e:67:bc:88:ec M2011
Fri Jul 21 10:58:54 2023 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/dhcp
Fri Jul 21 10:58:54 2023 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/radvd
Fri Jul 21 10:58:54 2023 user.notice ucitrack: Setting up /etc/config/wireless reload dependency on /etc/config/network
Fri Jul 21 10:58:54 2023 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/luci-splash
Fri Jul 21 10:58:54 2023 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/qos
Fri Jul 21 10:58:54 2023 user.notice ucitrack: Setting up /etc/config/firewall reload dependency on /etc/config/miniupnpd
Fri Jul 21 10:58:54 2023 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/odhcpd
Fri Jul 21 10:58:55 2023 user.notice ucitrack: Setting up non-init /etc/config/fstab reload handler: /sbin/block mount
Fri Jul 21 10:58:55 2023 user.notice ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Fri Jul 21 10:58:55 2023 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/luci_statistics
Fri Jul 21 10:58:55 2023 user.notice ucitrack: Setting up /etc/config/system reload dependency on /etc/config/dhcp
Fri Jul 21 10:59:10 2023 daemon.err uhttpd[7034]: bind(): Address in use
From the log, 2.4G radio is not on, but didn’t show any wifi driver crash etc.
Can you try these commands via ssh terminal and give the result?
ifconfig
iwinfo
Then, can you do a firmware reset, or upgrade to latest firmware without keep settings. This will resolve most of the config messed up issues.
I did a full factory reset when the issue 1st appeared and it did not resolve.
Can you explain why the lights on the unit are not working either?
I’ll get the output of those 2 commands later today.
The output from the commands requested
root@GL-X750:~# ifconfig
br-lan    Link encap:Ethernet  HWaddr E4:95:6E:46:E0:65
          inet addr:192.168.8.1  Bcast:192.168.8.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:1575186 errors:0 dropped:154824 overruns:0 frame:0
          TX packets:3698206 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:130786091 (124.7 MiB)  TX bytes:5196641853 (4.8 GiB)
eth0      Link encap:Ethernet  HWaddr E4:95:6E:46:E0:64
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          Interrupt:4
eth1      Link encap:Ethernet  HWaddr E4:95:6E:46:E0:65
          RX packets:220946 errors:0 dropped:11 overruns:0 frame:0
          TX packets:34787 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:29435346 (28.0 MiB)  TX bytes:3248435 (3.0 MiB)
          Interrupt:5
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:8501 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8501 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1362719 (1.2 MiB)  TX bytes:1362719 (1.2 MiB)
wlan0     Link encap:Ethernet  HWaddr E4:95:6E:46:E0:67
          RX packets:1370222 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3830587 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:129908891 (123.8 MiB)  TX bytes:5285669984 (4.9 GiB)
wlan1     Link encap:Ethernet  HWaddr E4:95:6E:46:E0:66
          TX packets:159368 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:12656561 (12.0 MiB)
wwan0     Link encap:Ethernet  HWaddr 1A:01:86:86:B0:F1
          inet addr:10.97.107.148  Bcast:10.97.107.151  Mask:255.255.255.248
          inet6 addr: fe80::1801:86ff:fe86:b0f1/64 Scope:Link
          UP BROADCAST RUNNING NOARP MULTICAST  MTU:1500  Metric:1
          RX packets:3733374 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1465631 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:5142168996 (4.7 GiB)  TX bytes:127165514 (121.2 MiB)
root@GL-X750:~# iwinfo
wlan0     ESSID: "GL-X750-064-5G"
          Access Point: E4:95:6E:46:E0:67
          Mode: Master  Channel: 36 (5.180 GHz)
          Tx-Power: 20 dBm  Link Quality: 38/70
          Signal: -72 dBm  Noise: -94 dBm
          Bit Rate: 6.0 MBit/s
          Encryption: WPA2 PSK (CCMP)
          Type: nl80211  HW Mode(s): 802.11nac
          Hardware: 168C:0050 0000:0000 [Qualcomm Atheros QCA9887]
          TX power offset: none
          Frequency offset: none
          Supports VAPs: yes  PHY name: phy0
wlan1     ESSID: "GL-X750-064"
          Access Point: E4:95:6E:46:E0:66
          Mode: Master  Channel: 11 (2.462 GHz)
          Tx-Power: 20 dBm  Link Quality: unknown/70
          Signal: unknown  Noise: -89 dBm
          Bit Rate: unknown
          Type: nl80211  HW Mode(s): 802.11bgn
          Hardware: unknown [Generic MAC80211]
          TX power offset: unknown
          Frequency offset: unknown
          Supports VAPs: yes  PHY name: phy1
The iwinfo does show the 2.4G WiFi is active.
While the LEDs snows that 2.4G WiFi is not active. This could be a wrong config of led but as you reset the firmware, this should not be the case.
Maybe you can try change WiFi channel and check.
Also try using the 4.x firmware. If still the same, then we can conclude it is radio defective.
Thanks. I don’t think the issue is just with the LED configuration. Feels more like a hardware problem to me.
I think maybe I’m not being clear about the LED. Notice that the power light is also not on? It should always be on but the power light never comes on. Also the LEDs are always as I showed in the picture. Even if I disconnect the WAN or 5ghz WiFi the lights stay on l.
And they are like that from the moment I plug in the power before the router has had any time to boot up.
If one LED always dark, then the LED could be just defective itself.
Yes I guess it could be but that does not explain the WAN, 5ghz WiFi, LTE lights being on permanently from the moment I plug in the power (before the router has even booted up) and stay on regardless of if there is a WAN or 5ghz WiFi etc.
Note also that the WAN, 5ghz WiFi lights are half brightness.
You can see the user @carrata above seems to have had a similar issue.
Also @But6ejxFBSNNCKj63M8U had the same issue. Looks like you asked them to return the router. Did you find the issue? I need the 2.4ghz Wifi.
Just send email to customer service cs at gl-inet.com
