2025-09-20 : IP Traffic issolation / bleed between …
I have several questions and will post them each individually to keep threads clean
  • Are clients on an Guest SSID isolated from each other? Isolated from all traffic on the hardware Ethernet ports and main, non-Guest, wifi SSID’s?
  • Are clients on the main, not Guest SSID isolated from each other?
My general intuitive expectation is that clients on a Guest SSID can only see what they get to when routed through the WAN hardware port.
My general expectation is that clients can freely interact if they are on either any main SSID, not guest, or on any of the physical Ethernet ports.
Thank you,
Your expectations are correct.
  • Guest WIFI clients are isolated from each other, and are also isolated from Main WIFI and Ethernet LAN.
  • Main WIFI clients are not isolated by default, you can enable it:
