What would you estimate the real world / stable throughput of qty 2 Beryl ax routers - 1 Beryl AX acting as an AP, and 1 Beryl AX configured as WDS station in 2.4 ghz. To be clear no other 2.4 clients will be served. LOS with acceptable SNR - 100 feet apart. TIA
Sorry for the late reply.
We haven’t specifically tested this scenario yet.
Also, since wireless environments can vary significantly, our data may not be very meaningful for your case.
The MT3000’s 2.4GHz Wi-Fi supports up to 574 Mbps, so in real-world usage, it typically won’t exceed around 250+ Mbps.
Thanks for your reply Will - anywhere north of 200 would be great for many applications.
I am going to test later this week.
