Does anyone have any details on this - what kind of leaks? would it affect openvpn client users (or wireguard client)?
I did not observe any leak when using regular online tests but I would like to know if my traffic may have been exposed.
Thanks
Thanks
It is data leak on ipv6. If you do not have ipv6 then it is OK.
My ISP does have ipv6 enabled, but I’m using openvpn with a commercial VPN provider that doesn’t support ipv6.
Therefore I assume that I would only have been leaking some local ipv6 chatter at worst to my local network, since my traffic is tunneled over ipv4 to the VPN provider.
I am not 100% sure that that is how it works though, hence the question.
Yes you are right.
Yes you are right.
Is a 3.101 build available for testing/download for ar300m?
Or are there any mods I can do to disable ipv6 on ovpn interface (when I’m trying via luci I see it pops back up as soon as I reconnect to VPN?)
just curious, is this leak when using wireguard?
