help me please to setup the 3G modem for the AR-150 router.
The model i use is Huawei E1550. Is works with another routers. But with that model it is just blinking blue color led. It can see the network, but can not connect to it. Any ideas what can i do with that?
Of course APN, login and password are correct.
Is there any compatibility problems with Russian mobile networks?
You were totally right. I set it to ttyUSB0 and it started to work correctly.
The next question is about network services.
Our mobile networks are not works in CDMA/EVDO. So the only way is to connect in WCDMA. It is the slowest 3G here.
Is there a chance to get it work in HSPDA (H, H+)?
