4.5.19 firmware not compatible with Marble GL-B3000
When attempting to upgrade from 4.5.10 to 4.5.19 I get the following issue:
Tried both online upgrade and by manually uploading the file. And also tried unchecking "Keep settings" option.
Any ideas?
Try to upgrade with Uboot debrick: Debrick via Uboot - GL.iNet Router Docs 4
Thanks :slight_smile: That did the trick. These GL.inet routers rock. So easy to tweak and configurate.
