GL-AX1800 4.7.0 using Wireguard cascading, and sometimes TOR.
After enabling, then disabling Tor, within several hours, the router would go in to a reboot loop. I would have to physically unplug it. Eventually it would boot successfully.
I discovered the issue was with NETWORK ACCELERATION being enabled.
After disabling Network Acceleration, all my issues went away.
It has been about two weeks and the router is perfectly stable again.
Network acceleration seems to have some conflict with Tor or Tor+Wireguard.
I did not test extensively.
I will try to reproduce this on my router.
But if this issue is confirmed to relate with the Network Acceleration, may difficult to fix it, as the code of Network Acceleration is Qualcomm closed-source, only submit to the Qualcomm to fix it.
Please disable the Network Acceleration to use at present.
I just rolled back way to the last working update which is 4.4.6 because it was the only one that worked with SQM. All the updates past this if you reboot you have to go and restart the SQM software or it won't be on. But 4.7 is a disaster. Lost connections and random reboots and no answers.
