I've migrated from version 4.7.7 to 4.8 beta4, and I’ve encountered an issue when trying to create a profile for a wireguard server.
I understand that this is beta software, but this particular issue seems like a blocker, maybe someone from the dev will take a look.
To rule out any leftover config issues, I even performed a full firmware reset and tried again, but the problem persists.
The "apply" button does absolutely nothing when setting up the WireGuard profile.
I’ve attached a video bellow.
gateway-Admin-Panel.zip (1.6 MB)
I tested mine and it works OK.
I have no idea what is happening, I already restarted to defaults 3 times already, tried multiple browsers and different OSes to exclude everithing.
Same issue.
bruce
5
May I confirm did you remove the IPv6 address in the VPN server?
If yes, we are aware this issue, thanks for your feedback, R&D already checked this.
Hi Bruce,
yes, you are right, if I populate the ipv6 field, everything is back to normal.
I don't use IPv6 address and by default I have the tendency to remove it.
Thanks!
bruce
8
Thanks for your confirmation, will improve it in the future firmware version.
system
Closed
10
