Eric97
March 28, 2022, 9:38am
Hello GL.iNet community,
Recently purchased the GL-MV1000 BRUME model and a 4G DLink DWM222 dongle . Expecting to set up 3G/4G in the admin page. But the DLink was only recognized as UBS tethering device and thus does not have Internet.
Can ask if the DLink DWM222 4G dongle is supported in the firmware? As I have tested the dongle in my host machine with Ubuntu 20.04 installed and working fine. Thank you.
Best regards,
Eric
alzhao
March 28, 2022, 11:12am
2
It is recognized as USB tethering device and should be able to work as tethering, right?
Happi
March 29, 2022, 8:08am
3
I tried one on an AR300M and it is recognised as a 3G/4G modem (device = /dev/cdc-wdm0).
Eric97
April 1, 2022, 8:07am
4
Thank you both.
Sorry for the late update. I just tried to ssh into the router. After plugging into the DLink dongle, the Brume itself can ping google.com .
But when I connected my laptop to the Brume router through LAN cable with DHCP, my laptop unable to ping google.com .
Is there any other configurations needed to enable the LAN clients to have internet? Thank you.
Best,
Eric
alzhao
April 1, 2022, 10:28am
5
ssh to the router and use the following command and get the output.
ifconfig
route
Eric97
April 2, 2022, 1:51am
6
root@GL-MV1000:~# ifconfig
br-lan Link encap:Ethernet HWaddr 94:83:C4:0A:44:E9
inet addr:192.168.8.1 Bcast:192.168.8.255 Mask:255.255.255.0
inet6 addr: fdba:fe30:21f2::1/60 Scope:Global
inet6 addr: fe80::9683:c4ff:fe0a:44e9/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2138 errors:0 dropped:0 overruns:0 frame:0
TX packets:1790 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:344383 (336.3 KiB) TX bytes:1480760 (1.4 MiB)
eth0 Link encap:Ethernet HWaddr 94:83:C4:0A:44:E8
inet6 addr: fe80::9683:c4ff:fe0a:44e8/64 Scope:Link
TX packets:1797 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:532
RX bytes:391419 (382.2 KiB) TX bytes:1495906 (1.4 MiB)
Interrupt:9
lan0 Link encap:Ethernet HWaddr 94:83:C4:0A:44:E9
lan1 Link encap:Ethernet HWaddr 94:83:C4:0A:44:E9
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:225 errors:0 dropped:0 overruns:0 frame:0
TX packets:225 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:15036 (14.6 KiB) TX bytes:15036 (14.6 KiB)
usb0 Link encap:Ethernet HWaddr 8E:83:C4:FF:44:E8
usb1 Link encap:Ethernet HWaddr FA:F1:72:70:24:77
inet addr:192.168.0.25 Bcast:192.168.0.255 Mask:255.255.255.0
inet6 addr: fe80::f8f1:72ff:fe70:2477/64 Scope:Link
RX packets:75 errors:0 dropped:0 overruns:0 frame:0
TX packets:35 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4596 (4.4 KiB) TX bytes:5402 (5.2 KiB)
wan Link encap:Ethernet HWaddr 94:83:C4:0A:44:E8
root@GL-MV1000:~# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.0.1 0.0.0.0 UG 30 0 0 usb1
192.168.0.0 * 255.255.255.0 U 30 0 0 usb1
192.168.8.0 * 255.255.255.0 U 0 0 0 br-lan
The Gateway IP is correct?
alzhao
April 4, 2022, 7:53am
7
The route table seems OK.
Maybe just a DNS problem. Can you set up custom DNS in the router? Set to 8.8.8.8 and 8.8.4.4
Eric97
April 11, 2022, 10:18am
8
Just update that it is working now. Think the culprit is my local ubuntu Ethernet setting configured to be using on local network only. Thanks for the support!
