When will the 5G 802.11ac add on card be available for the AR300M? Can you please allow us to add an external antenna if we are willing to drill our own hole in the case?
AR300MD will be replaced by a new model and will be out soon.
alzhao, you’re routers are just amazing! Keep on going. When will that be out? 2 ethernet ports as well? :>
Just saw the AR-750 page. Give it an external antenna port and I will buy it immediately once it’s there!
I have tried to replace the antenna with some device but the effect is not ideal.
so I think the radio frequency rf chip is the most important for the coverage area.
