5G SA questions concerning GL-X3000
I’m loving my new GL-X3000 and all of the customizations that it allows me.
I have noticed one peculiar issue, though.
When I have the modem set to SA mode, restarting the modem causes the connection to hang until I manually apply settings to the SIM, then it connects.
I’ve also noticed that if I set the band lock to n71, it does not aggregate n71+n71.
Is this a limitation of the modem, or would that be a limitation of my carrier?
I have the same exact questions as you and also the issue where after restart the profile has to be manually set for internet to be back up.
