hey
i need mount swap in my Gl-inet 6416, but default /etc/config/fstab is empty and block-mount is not installed. This is normal? (USB hotplug is work and mount in /mnt/sda1)
how do I mount swap?
hey
Block mount is just some scripts I think. You can try to modify files like /etc/mtab or /etc/fstab, I don’t know which file. But not /etc/config/fstab
