Do you have plans to release a unit with 802.11ac support?
I’m currently using TP-Link Archer C7 v2, which is very stable running OpenWRT.
Do you think you could use a similar chipset, so we can have 802.11AC support with one of your units?
Also the range and power output of the C7 is not very impressive, even though it is stable.
It would be great if you could use a similar well-supported chipset, but with better power output and antenna options.
We have 802.11ac model, like GL-MT750 and working GL-AR300M 5G add-on. But both not released yet.
