Hi, I’d like to know if this 802.11r works on the Slate AX before buying.
And if so, would inter-operate with an older implementation (Slate)?
And in fact, are the Slate AX Wifi drivers native (like on the Slate) where pretty much everything can be configured and controlled on Luci, as opposed to Beryl’s which were a closed box and at the end of the day could be configured only with the GL interface (and 802.11r was dropped due to buggy).
GL-AXT1800(Mine is running firmware 4.1.0 release6)
wpad-openssl is installed and is the only available package
I have not personal tried fast roaming.
@K3rn3l_Ku5h Thanks for the response and special thanks for the tip on the Beryl! Let me tell you if you have the need and the hardware, this roaming thing rocks. Silky smooth.
