Just had the amusement of finding one after another seemingly “official Comfast” stores on Aliexpress. Ended up ordering a couple Comfast CF-953AX units which are said to be supported directly with recent Linux kernels.
At least from what I understand, Apple support for WiFi 6 is recent iPhones, some iPads, and Macs with Apple silicon. 6E support is only a couple of iPads.
I’m going to poke around to see if I can connect it to another WiFi 6 unit. One of the things I’m interested in is if the 2.4 GHz enhancements get me a more reliable link from one building to another here. Though the 5 GHz link is robust in dry weather, this last week of storms in California has shown how much that degrades with rain. The 2.4 GHz link stays up, but isn’t fast enough for our use case.
Has anyone configured these to interoperate with 802.11s and ideally BATMAN V routing?
(I do have hand-configured 802.11s running on my Linksys EA8300s. It is more a question of if there is a good way to configure it without “breaking” the GL.iNet applications.)
Edit:
Is there the equivalent of iw phy phy0 info
for the Mediatek devices?
Although I’ve installed the iw-full
and iwinfo
packages, iw
doesn’t seem to see the wireless devices and iwinfo
doesn’t supply detailed capability information.
From another device and an ath9k-htc interface, the kind of information I’m used to seeing is
jeff@front:~$ iw phy phy3 info
Wiphy phy3
wiphy index: 3
max # scan SSIDs: 4
max scan IEs length: 2257 bytes
max # sched scan SSIDs: 0
max # match sets: 0
Retry short limit: 7
Retry long limit: 4
Coverage class: 0 (up to 0m)
Device supports RSN-IBSS.
Device supports T-DLS.
Supported Ciphers:
* WEP40 (00-0f-ac:1)
* WEP104 (00-0f-ac:5)
* TKIP (00-0f-ac:2)
* CCMP-128 (00-0f-ac:4)
* CCMP-256 (00-0f-ac:10)
* GCMP-128 (00-0f-ac:8)
* GCMP-256 (00-0f-ac:9)
* CMAC (00-0f-ac:6)
* CMAC-256 (00-0f-ac:13)
* GMAC-128 (00-0f-ac:11)
* GMAC-256 (00-0f-ac:12)
Available Antennas: TX 0x1 RX 0x1
Configured Antennas: TX 0x1 RX 0x1
Supported interface modes:
* IBSS
* managed
* AP
* AP/VLAN
* monitor
* mesh point
* P2P-client
* P2P-GO
* outside context of a BSS
Band 1:
Capabilities: 0x116e
