Thank you, I look forward to hearing back from you.
Spinning a snapshot with (supposedly) full lxc compat now. Will let you know
root@OpenWrt:~# lxc-checkconfig
LXC version 5.0.1
--- Namespaces ---
Namespaces: enabled
Utsname namespace: enabled
Ipc namespace: enabled
Pid namespace: enabled
User namespace: enabled
Network namespace: enabled
--- Control groups ---
Cgroups: enabled
Cgroup namespace: enabled
Cgroup v1 mount points:
/sys/fs/cgroup/systemd
Cgroup v2 mount points:
/sys/fs/cgroup
Cgroup v1 freezer controller: missing
Cgroup v1 clone_children flag: enabled
Cgroup device: missing
Cgroup sched: enabled
Cgroup cpu account: enabled
Cgroup memory controller: enabled
Cgroup cpuset: enabled
--- Misc ---
Veth pair device: enabled, loaded
Macvlan: enabled, loaded
Vlan: enabled, not loaded
Bridges: enabled, not loaded
Advanced netfilter: enabled, loaded
CONFIG_IP_NF_TARGET_MASQUERADE: missing
CONFIG_IP6_NF_TARGET_MASQUERADE: missing
CONFIG_NETFILTER_XT_TARGET_CHECKSUM: missing
CONFIG_NETFILTER_XT_MATCH_COMMENT: enabled, loaded
FUSE (for use with lxcfs): missing
--- Checkpoint/Restore ---
checkpoint restore: missing
CONFIG_FHANDLE: enabled
CONFIG_EVENTFD: enabled
CONFIG_EPOLL: enabled
CONFIG_UNIX_DIAG: missing
CONFIG_INET_DIAG: missing
CONFIG_PACKET_DIAG: missing
CONFIG_NETLINK_DIAG: missing
File capabilities:
Note : Before booting a new kernel, you can check its configuration
usage : CONFIG=/path/to/config /usr/bin/lxc-checkconfig
Do you have the ability to create a working LXC container?
Create yes, if there’s enough disk space. Running into some config issues, but should be fixable I think.
Alpine takes up very little space. Were you able to get this distro up and running?
Thank you very much for your help. I wonder if it would be possible to run Ubuntu in the case of extroot in A1300.
@alzhao
Would it be possible to add dependencies in the official firmware that will allow lxc to run?
As you can see, you don’t need much. Just use the free OpenWRT source.
No way for Ubuntu on A1300
Without checking more details I wonder if this model is powerful enough.
@jdub do you have extroot configured on the A1300? If so, could you try running Ubuntu in LXC?
Thank you very much in advance for your help. I am curious myself if on this device and if it starts, will apt and other applications work.
I don’t know if we understood each other correctly, but I meant Ubuntu in an LXC container on A1300. The host in this case very much stays OpenWRT.
The kernel and regular Ubuntu is too heavy for the A1300.
I don’t, and the image is too large for the available space. Probably not something I’ve got time to do in the short term, sorry.
I see. If I find some more time, I’ll try to run extroot or file link on A1300. I’m just curious if it will run and how it will work.
