Anyone else with a GL-E5800(EU) seeing /etc/sys_log getting pretty big?
Mine is already around 151 MB (100MB days ago) and seems to keep being written to:
-rw------- 1 root root 151.1M May 11 22:38 sys_log
Disk space is still fine, but I’m wondering if this is normal or if something is logging too much.
root@GL-E5800:/etc# ls -lah|grep log
-rw-r--r-- 1 root root 0 Jul 16 2024 syslog.conf
root@GL-E5800:/etc# df -h
Filesystem Size Used Available Use% Mounted on
/dev/root 764.4M 482.1M 266.5M 64% /rom
tmpfs 799.2M 17.5M 781.6M 2% /tmp
/dev/mmcblk0p59 2.9G 176.1M 2.5G 6% /overlay
overlayfs:/overlay/rootfs-upper
tmpfs 512.0K 0 512.0K 0% /dev
/dev/mmcblk0p55 299.9M 213.0M 86.9M 71% /firmware
/dev/mmcblk0p60 41.8M 47.0K 38.3M 0% /cache
/dev/mmcblk0p61 10.1M 996.0K 8.2M 11% /persist
/dev/mmcblk0p66 1.3G 354.7M 937.2M 27% /usrdata
/dev/mmcblk0p66 1.3G 354.7M 937.2M 27% /data
/dev/mmcblk0p66 1.3G 354.7M 937.2M 27% /systemrw
/dev/mmcblk0p66 1.3G 354.7M 937.2M 27% /cache/ufs
root@GL-E5800:/etc#
I do a little tail, and here is:
Mon May 11 22:34:56 2026 user.err Diag_Lib[15649]: (sim.c:477) No APN node found for mcc:460 mnc:06
Mon May 11 22:34:59 2026 daemon.err odhcp6c[10791]: Failed to send SOLICIT message to ff02::1:2 (Network unreachable)
Mon May 11 22:35:06 2026 user.err Diag_Lib[15649]: (sim.c:477) No APN node found for mcc:460 mnc:06
Mon May 11 22:35:16 2026 user.err Diag_Lib[15649]: (sim.c:477) No APN node found for mcc:460 mnc:06
Mon May 11 22:35:26 2026 user.err Diag_Lib[15649]: (sim.c:477) No APN node found for mcc:460 mnc:06
Mon May 11 22:35:36 2026 user.err Diag_Lib[15649]: (sim.c:477) No APN node found for mcc:460 mnc:06
Mon May 11 22:35:46 2026 user.err Diag_Lib[15649]: (sim.c:477) No APN node found for mcc:460 mnc:06
Mon May 11 22:35:50 2026 user.info LocSvc_LocationIntegrationApiIm[13072]: proc:466] >-- onReceive Rcvd msg id: 99, sockname: locapiservice, payload size: 160
Mon May 11 22:35:50 2026 user.warn LocSvc_LocationIntegrationApiIm[13072]: proc:614] <<< unknown message 99
Mon May 11 22:35:50 2026 user.info LocSvc_LocationClientApi[13072]: proc:3475] >-- onReceive Rcvd msg id: 99 E_LOCAPI_PINGTEST_MSG_ID, sockname: locapiservice, payload size: 160
Mon May 11 22:35:54 2026 kern.err kernel: [15249.854747][ C0] [soft_i][0x443418ee92][22:35:54.000450] wlan: [0:E:DP] dp_tx_prepare_tso: Failed to alloc tso seg desc
Mon May 11 22:35:56 2026 user.err Diag_Lib[15649]: (sim.c:477) No APN node found for mcc:460 mnc:06
Mon May 11 22:36:06 2026 user.err Diag_Lib[15649]: (sim.c:477) No APN node found for mcc:460 mnc:06
Mon May 11 22:36:16 2026 user.err Diag_Lib[15649]: (sim.c:477) No APN node found for mcc:460 mnc:06
Mon May 11 22:36:26 2026 user.err Diag_Lib[15649]: (sim.c:477) No APN node found for mcc:460 mnc:06
Mon May 11 22:36:36 2026 user.err Diag_Lib[15649]: (sim.c:477) No APN node found for mcc:460 mnc:06
Mon May 11 22:36:46 2026 user.err Diag_Lib[15649]: (sim.c:477) No APN node found for mcc:460 mnc:06
(The network is fine)
how big is your /etc/sys_log?
Does it design to be keep growing, or is it rotated/cleared at some point?
Also curious whether this being written to persistent storage could be an issue long-term (you know, flash/eMMC wear stuff), or if I’m overthinking it. Would it be better for this log to be stored under /tmp/log & rotated more aggressively?
