this is not command in windows
I use ping 192.168.10.1 and get reply
I use ping 192.168.1.1 and it times out
I use tracert 192.168.10.1 and get 1 hop
I use tracert 192.168.1.1 and get my VPN IP Address, which then goes through 2 more IP Addresses
I use ping on those 2 IP address and each is 1 TTL less than the previous, the times out, both are on the cloud provider
