Is it possible to add B2B.static for T-Mobile static IP addresses to the list of APN’s in the APN dropdown box? For some reason customers can’t seem to type that in correctly … Thanks!! (My current need is MiFi, Spitz and Amarok …)
You can choose to set it manually and then set the APN you want in the input box of the APN.
Yes this is how we do it right now - but I sell these routers to end users that aren’t at all technical. It would be great if it were in the dropdown … ;]
You can do some pre-configuration in the router, you may need to compile the firmware yourself.
