I have been trying for a week to activate i2c and UART TTL without success.
How to enable i2C and UART on this router?
I am in version 3.201 (OpenWRT 07/19.7, ath79).
I have access to a computer running linux, windows, … but I don’t know where to start.
My final goal is to create an NTP service via GPS + pps associated with i2c sensors in order to have a measurement of the environment.
I already know how to do all this without worries via python3 on an RPI. But there I am blocked without having access to the i2c (for the capteurs) and the UART TTL (for the GPS)
I wanted to install i2c tools but it conflicts with busybox. I would like to use the i2cdetect command. Do you have a solution ?
for the TTL UART I saw that there were ttySXX present. Only ttyS0 to work. I have not yet tried to communicate via this interface. How to deactivate the console @alzhao ?
I also saw that there was a 4 pin connector with the connector of a USB port (GND, DP, DM, VCC 5V) is it usable if we connect it to a USB port?
Thanks for your help as I really can’t find any info on this router.
[Hoff] Please use opkg install i2c-tools --force-overwrite command to install the i2c-tools package.
