krija
Just tested your DPI feature.
And it is lack of protocol detection. Like P2P.
This is extremely useful to avoid "love letters" from isp.
Also, being unable to use ONLY my website list (without updating database) is inconvenient too. I have .txt file of domains I need to block.
Just add feature to upload .txt and option to disable factory database.
Thank you for your feedback.
At the moment, we already support detection of some P2P protocols, such as BitTorrent:
Could you further clarify whether there are other protocols you would like us to add, or whether your goal is to disable specific protocols?
If your goal is to block them, you can do so by selecting the corresponding applications in Content Filter:
Regarding this point, Content Filter should already support custom domain lists that you want to block.
It also allows you to deselect all predefined application categories so that only your custom domain list is used for filtering:
Could you further clarify how this differs from your intended use case, or what specific scenario is not covered by the current implementation?
