Add Phantap package to repository
Hello, I recently purchased the GL-SFT1200 for the purpose of installing the Phantap package. I have since discovered that it is not available in the GL-iNet repositories and have been researching how to get it installed. The source is on Github ( GitHub - nccgroup/phantap: Phantom Tap (PhanTap) - an ‘invisible’ network tap aimed at red teams ) and the package is available in the OpenWRT repositories ( packages/net/phantap at openwrt-21.02 · openwrt/packages · GitHub ). It looks like my device is based on a Siflower, MIPS sf19a28 architecture, and I expect to run into problems trying to compile the software myself. Before I attempt to do so, I am hoping you can do so easily and add it to the available package repository. Is this something you can do?
May we know the firmware version you are currently running?
Then we will ask the R&D to check if we can add this package to the repository for you.
Yes, thank you.
My SFT-1200 device is running v4.3.28
Thank you for the update.
We've already had the R&D team check whether we can add it.
It has been added to the repository, please check.
I see it on my device now. Thank you very much!
