ADguard doesn't work after add several custom DNS lists. How to reset it pleasE?
I have a GL net 6000, all is working fine except Adguard...
This is the log message:
ed Mar 5 15:13:17 2025 kern.info kernel: [753707.713998] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/,task=AdGuardHome,pid=23731,uid=0
Wed Mar 5 15:13:17 2025 kern.err kernel: [753707.727091] Out of memory: Killed process 23731 (AdGuardHome) total-vm:1930468kB, anon-rss:687636kB, file-rss:0kB, shmem-rss:0kB, UID:0 pgtables:1464kB oom_score_adj:0
How to reset it please ? I guess is using ssh, but any help would be appreciated
Unfortunately your lists were too big and killed AdGuard Home because RAM is full.
You can remove those filter lists by editing the /etc/AdGuardHome/config.yaml - just remove the filters from filters:
Thanks a lot ! Worked perfectly. Just used vi as editor, but all is perfect !
Thanks
I am but a lowly noob when it comes to Openwrt or my new Flint 2 MT6000, but I'm eager to learn. So I got into the shell and looked at the config.yaml file out of curiosity. But then it occurred to me - can't you accomplish the same thing using the AdGuard GUI interface? The filters tab seems like it provides the ability to add/remove/edit the filter file contents so you can just disable any you don't want through the GUI. I'm guessing this is reflected in the config.yaml file when applied.
Correct? I guess 'pros' do most of this stuff through the CLI, which is definitely worth learning and understanding. But if you just need a quick adjustment, the GUI should suffice?
Yeah it does, but if the filter list is too big, the GUI won't load :wink:
