Have you tried setting the dhcp-option for assigning the AGH server for DNS in dnsmasq to your DHCP clients?
Inside of Luci, you can go to Network>Interfaces>LAN(edit)>DHPC Server Tab>Additional Settings and under dhcp-options at the bottom add 6,<IP address of AGH> to ensure your clients use AGH for DNS service.
@Bitty_Bytes no didn’t tested thanks for the tip it’s not really a problem with the dns it was just strange why my windows pc shows Vpn dns and use my isp connection
Update:
Pc dns is fixed looks like a installed Vpn app changed dns settings
The other pc which uses Vpn still use adguard home dns is this correct?
So if you enable override for all clients it should always use the adguard DNS. This should work even if your DNS is hard coded on the computer like from the VPN app.
