Adguard Home no longer working on my Beryl
I was playing around with new lists. I tried to add this: https://raw.githubusercontent.com/hagezi/dns-blocklists/main/adblock/tif.txt
This is HageZi’s Threat Intelligence Feed. I probably should have added the feed from the list included with the Beryl instead of from GitHub. After I added the list, within moments, I lost internet connection. Couldn't figure out why. When I try to go back to Adguard Home, nothing appears. It says it’s trying to load, but nothing is visible. I only got internet back after disabling Adguard Home. What do I do now? Is there a way to get Adguard Home to load up again and I'll remove the feed that caused the problem to begin with?
You can edit the config file to disable that list (I believe it's in /etc/adguardhome/config.yaml) and reload adguardhome.
Use the TIF mini version from github instead. The one from the included lists is also the full version and it's gonna crash again.
I'm sorry, but I'm a total newbie here. How do I access the config file to disable the list?
WinSCP is probably the most user friendly.
If I don't have a PC on hand, is there any other way to do this?
With goodcloud you can use ssh from your browser remotely
Or install openssh-sftp-server from plug-ins and use a file manager from your phone
If the SSH operation in the phone is difficult, may consider resetting the firmware and then reconfiguring them.
This might be the way to go. How do I do that? I'm assuming after I reset it, it'll be like as if I installed a new Beryl? The mistake that I made with the Hagezi list should be deleted?
Help?
Thank you! So if I reset the firmware in web Admin Panel, I'm assuming even the password into the Beryl will be reset as well? Basically everything will be reset like as if its a new Beryl out of the box with all settings at default?
Yes, this understand is correct. :wink:
