Adguard Icon missing from Opal
So i recently picked up the GL-SFT1200 (Opal) and i upgraded the firmware to 4.1.1 beta1 and i have lost access to Adguard, as the interface is no longer there (see screenshot). I did install adguard from the application list and restarted the router but no luck
As a side note i also have the Flint and i upgraded it to 4.x.x as well and i have access to Adguard home was the feature removed from the opal from the 4.1.1 firmware?
Flint router
Through Luci i have installed Adguard home in my opal but i dont see the icon in the default page
SFT1200 is not poweful enough to run AdguardHome.
Does the function work well when you install and enable?
I installed adguardhome on the Opal with 3.215 and as long as you do not burden the CPU with huge blocklists, it runs fine. If I activate a large blocklist, the load average will skyrocket and crash the router. Here is my filter list from config.yaml on the Opal:
filters:
- enabled: true
  url: https://adguardteam.github.io/AdGuardSDNSFilter/Filters/filter.tx
  name: AdGuard Simplified Domain Names filter
- enabled: true
  url: https://adaway.org/hosts.txt
- enabled: true
  url: https://someonewhocares.org/hosts/zero/hosts
  name: Dan Pollock's List
- enabled: true
  url: https://abp.oisd.nl/basic/
  name: OISD Blocklist Basic
enabled: true
  url: https://pgl.yoyo.org/adservers/serverlist.php?hostformat=adblockp
  name: Peter Lowe's List
- enabled: true
  url: https://raw.githubusercontent.com/DandelionSprout/adfilt/master/A
  name: Dandelion Sprout's Anti-Malware List
- enabled: true
  url: https://raw.githubusercontent.com/crazy-max/WindowsSpyBlocker/mas
  name: WindowsSpyBlocker - Hosts spy rules
- enabled: true
  url: https://raw.githubusercontent.com/DRSDavidSoft/additional-hosts/m
- enabled: true
  url: https://raw.githubusercontent.com/alexsannikov/adguardhome-filter
- enabled: true
  url: https://raw.githubusercontent.com/AdguardTeam/FiltersRegistry/mas
It is not heavy use on the network, so load averages stay below 2 for the most part on the Opal, and was another reason that I purchased a 2nd gl.inet router for the upgraded CPU to run AGH.
On a side note, I run adguard home on a GL-X750 off of an 8Gb sdcard with only the 1 default blocklist and use AGH for the DNS over TLS, https and DNS over quic feature plus the custom filtering rules with the following:
/^(.+[_.-])?telemetry[_.-]/
/^ad([sxv]?[0-9]*|system)[_.-]([^.[:space:]]+\.){1,}|[_.-]ad([sxv]?[0-9]*|system)[_.-]/
/^adim(age|g)s?[0-9]*[_.-]/
/^adtrack(er|ing)?[0-9]*[_.-]/
/^advert(s|is(ing|ements?))?[0-9]*[_.-]/
/^aff(iliat(es?|ion))?[_.-]/
/^analytics?[_.-]/
/^banners?[_.-]/
/^beacons?[0-9]*[_.-]/
/^count(ers?)?[0-9]*[_.-]/
/^mads\./
/^pixels?[-.]/
/^stat(s|istics)?[0-9]*[_.-]/
It runs fine on the X750, but again its mainly light browsing only. YMMV
