AdGuard wont work on XE3000
Hey can everyome Show my log?
AdGuard wont start After restart in the Morning
AdGuardHome[25242]: 2025/09/28 08:34:04.690443 [info] AdGuard Home, version v0.107.66
Sun Sep 28 08:34:04 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:04.736362 [info] warning: no users in the configuration file; authentication is disabled
Sun Sep 28 08:34:04 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:04.757841 [info] tls_manager: using default ciphers
Sun Sep 28 08:34:04 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:04.771022 [info] webapi: initializing
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.727984 [info] dnsproxy: upstream mode is set mode=parallel
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.728107 [info] dnsproxy: cache enabled size=4096
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.728177 [info] dnsproxy: max goroutines is set count=300
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.728594 [info] dnsproxy: cache ttl override is enabled min=7200 max=86400
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.729115 [info] dnsproxy: ratelimit is enabled rps=20 ipv4_subnet_mask_len=24 ipv6_subnet_mask_len=56
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.729189 [info] dnsproxy: server will refuse requests of type any
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.729235 [info] dnsproxy: upstream mode is set mode=parallel
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.729284 [info] dnsproxy: cache enabled size=4194304
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.729337 [info] dnsproxy: max goroutines is set count=300
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.743976 [info] webapi: AdGuard Home is available at the following addresses:
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.746197 [info] go to http://127.0.0.1:3000
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.746298 [info] go to http://[::1]:3000
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.746332 [info] go to http://192.0.0.2:3000
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.746398 [info] go to http://[fe80::24c6:5abc:4442:d0e2%rmnet_mhi0]:3000
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.746426 [info] go to http://192.168.8.1:3000
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.746453 [info] go to http://10.5.0.2:3000
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.747702 [info] starting plain server server=plain addr=0.0.0.0:3000
Sun Sep 28 08:34:05 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:05.751448 [info] addrproc: processing addresses
AdGuardHome[25242]: 2025/09/28 08:34:23.816027 [info] dnsproxy: starting dns proxy server
Sun Sep 28 08:34:23 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:23.816204 [info] dnsproxy: creating udp server socket addr=0.0.0.0:3053
Sun Sep 28 08:34:23 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:23.816580 [info] dnsproxy: listening to udp addr=[::]:3053
Sun Sep 28 08:34:23 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:23.816669 [info] dnsproxy: creating tcp server socket addr=0.0.0.0:3053
Sun Sep 28 08:34:23 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:23.826266 [info] dnsproxy: listening to tcp addr=[::]:3053
Sun Sep 28 08:34:23 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:23.826597 [info] dnsproxy: entering udp listener loop addr=[::]:3053
Sun Sep 28 08:34:23 2025 user.notice AdGuardHome[25242]: 2025/09/28 08:34:23.827026 [info] dnsproxy: entering listener loop proto=tcp addr=[::]:3053
Aha. I solved it with a line that had to be written into the AdGuard init.d file.
I think this entry also belongs to:
MPTCP: mptcp need to implement this function: net/mptcp/subflow.c,subflow_v4_init_req,1791
procd_open_instance
procd_set_param respawn
procd_set_param group explict_vpn
procd_set_param stderr 1
procd_set_param env GODEBUG=multipathtcp=0
procd_set_param command /usr/bin/AdGuardHome --glinet -c /etc/AdGuardHome/config.yaml -w /etc/AdGuardHome -l syslog
procd_close_instance
[ -e /etc/edgerouter.fw ] && /etc/edgerouter.fw loaddns
I didn't see what was wrong with ADG in the log you attached, seems the process was normal to start.
Glad to see that you have solved it later. Thanks!
Unfortunately, I don't have a picture of the ads being set to 0. It was working recently. The AdGuard interface wouldn't open anymore, and the ads were set to 0 for hours.
  1. Did you upgrade the ADG plug-in separately?
  2. Are there some plug-ins installed on the router? and it occupy ports 3000?
  3. Will reset the firmware be normal?
