AdGuardHome (Configuration and errors)
I'm using AdGuardHome on my Flint 2 and I've noticed several errors. Could you tell me if my configuration is correct? Is there anything I can do to improve it and avoid these errors?
Thanks.
PS: Sorry for my English.
Screenshots of my configuration and attached file with the errors: Errores-AdGuardHome.zip
Errores-AdGuardHome.zip (8.2 KB)
Hi!
Based on the log provided, it appears that the issue stems from a network connectivity problem, which is preventing communication between the ADG home and the upstream DNS.
Please verify that you can access the internet and confirm whether the problem persists.
Will, thanks for your reply. I can access the internet. New errors.
Gracias
Dec 10 19:38:04 GL-MT6000 AdGuardHome 2025/12/10 22:38:04.493000 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:05 GL-MT6000 AdGuardHome 2025/12/10 22:38:05.502394 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:34 GL-MT6000 AdGuardHome 2025/12/10 22:38:34.513653 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:36 GL-MT6000 AdGuardHome 2025/12/10 22:38:36.072339 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:38 GL-MT6000 AdGuardHome 2025/12/10 22:38:38.074107 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:42 GL-MT6000 AdGuardHome 2025/12/10 22:38:42.113460 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:42 GL-MT6000 AdGuardHome 2025/12/10 22:38:42.756401 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:43 GL-MT6000 AdGuardHome 2025/12/10 22:38:43.274678 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:43 GL-MT6000 AdGuardHome 2025/12/10 22:38:43.279946 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:43 GL-MT6000 AdGuardHome 2025/12/10 22:38:43.774579 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:44 GL-MT6000 AdGuardHome 2025/12/10 22:38:44.288396 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:44 GL-MT6000 AdGuardHome 2025/12/10 22:38:44.290961 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:45 GL-MT6000 AdGuardHome 2025/12/10 22:38:45.052300 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:46 GL-MT6000 AdGuardHome 2025/12/10 22:38:46.054709 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:46 GL-MT6000 AdGuardHome 2025/12/10 22:38:46.059635 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:47 GL-MT6000 AdGuardHome 2025/12/10 22:38:47.065315 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:48 GL-MT6000 AdGuardHome 2025/12/10 22:38:48.063234 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:48 GL-MT6000 AdGuardHome 2025/12/10 22:38:48.069171 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:38:49 GL-MT6000 AdGuardHome 2025/12/10 22:38:49.052814 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:07 GL-MT6000 AdGuardHome 2025/12/10 22:41:07.552950 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:08 GL-MT6000 AdGuardHome 2025/12/10 22:41:08.618590 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:08 GL-MT6000 AdGuardHome 2025/12/10 22:41:08.625462 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:08 GL-MT6000 AdGuardHome 2025/12/10 22:41:08.630140 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:08 GL-MT6000 AdGuardHome 2025/12/10 22:41:08.634383 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:10 GL-MT6000 AdGuardHome 2025/12/10 22:41:10.059086 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:10 GL-MT6000 AdGuardHome 2025/12/10 22:41:10.062215 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:10 GL-MT6000 AdGuardHome 2025/12/10 22:41:10.067700 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:10 GL-MT6000 AdGuardHome 2025/12/10 22:41:10.071181 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:38 GL-MT6000 AdGuardHome 2025/12/10 22:41:37.995772 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:38 GL-MT6000 AdGuardHome 2025/12/10 22:41:38.004887 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:38 GL-MT6000 AdGuardHome 2025/12/10 22:41:38.015004 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:38 GL-MT6000 AdGuardHome 2025/12/10 22:41:38.019700 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:38 GL-MT6000 AdGuardHome 2025/12/10 22:41:38.027068 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:39 GL-MT6000 AdGuardHome 2025/12/10 22:41:39.043274 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:39 GL-MT6000 AdGuardHome 2025/12/10 22:41:39.046835 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:39 GL-MT6000 AdGuardHome 2025/12/10 22:41:39.050197 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:39 GL-MT6000 AdGuardHome 2025/12/10 22:41:39.054099 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:39 GL-MT6000 AdGuardHome 2025/12/10 22:41:39.056954 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:40 GL-MT6000 AdGuardHome 2025/12/10 22:41:40.062381 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:40 GL-MT6000 AdGuardHome 2025/12/10 22:41:40.069055 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:40 GL-MT6000 AdGuardHome 2025/12/10 22:41:40.072550 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:40 GL-MT6000 AdGuardHome 2025/12/10 22:41:40.076251 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:40 GL-MT6000 AdGuardHome 2025/12/10 22:41:40.079692 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:41 GL-MT6000 AdGuardHome 2025/12/10 22:41:41.073463 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:41 GL-MT6000 AdGuardHome 2025/12/10 22:41:41.077307 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:41 GL-MT6000 AdGuardHome 2025/12/10 22:41:41.081188 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:41 GL-MT6000 AdGuardHome 2025/12/10 22:41:41.085181 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:41 GL-MT6000 AdGuardHome 2025/12/10 22:41:41.088954 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 10 19:41:42 GL-MT6000 AdGuardHome 2025/12/10 22:41:42.043536 [error] auth: opening token file err="open /tmp/gl_token_b4Ekhy4dgfthfbvH2YGY7B03A6T8DtDw: no such file or directory"
Dec 11 03:54:25 GL-MT6000 AdGuardHome 2025/12/11 06:54:24.897741 [error] dnsproxy: reading msg proto=tcp err="reading msg: unexpected EOF"
The built-in ADG Home access is authenticated via a session/token created when you log in through the GL UI.
This error is commonly seen when:
  • ADG Home is opened directly (bookmark/direct URL) rather than from the GL UI, or
  • the browser tab has been left open and the session/token has expired (re-opening from the GL UI usually resolves it).
If ADG Home is accessible and working as expected, these log entries are generally harmless and can be ignored.
Thanks. Does my configuration look okay to you? Do you have any links to documentation on how to configure Adguarhome on Flint 2 routers?
Your configuration looks fine.
For documentation, we currently have a guide on enabling this feature specifically for GL.iNet routers:
If you want to explore AdGuard Home’s features in more detail, we recommend reviewing its official Wiki:
gracias
