After new ISP connection, no Internet detection, gldns not refreshes
Hi. My ISP recently changed G.Fast via Draytek modem to opticfiber with ONT. After this change, I still use PPPoE but instead setting up VLAN ID on modem I do have it in Flint 2.
After reboot of the router, I see notification no internet, but it is working. So I disabled probing under Multi-WAN. Also glddns seems not refreshing, I need to switch it off and on again. In Luci I have configured afraid ddns , but is always stopped after reboot, again, manual reload within Luci interface helps.
Not sure if this is somehow related, but it is all happening after new ISP line.
Regarding the Ethernet detection issue, it may be caused by poor compatibility between the new ISP line and Multi-WAN. We suggest:
  1. If you only have a single WAN available, disabling this feature should not have any impact.
  2. You could also try adjusting the Sensitivity Options or Track IP settings in Multi-WAN to see if that resolves the issue.
For the DDNS issue, please refer to the following to workaround:
The fix will be integrated into the next firmware release.
