Aircove ax1800 to gl.inet can it be done
I have aircove express vpn travel router ax1800 I stated using Tailscale. Can I convert my router to gl.inet code that supports Tailscale?
The GL firmware of AX1800 is supported the Tailscale feature, you can enable that on GL GUI.
My question was can I put gl firmware on the aircove? I tried the uboot on the router and it does not like the firmware says it is wrong.
Listen to that message!
