Amazon fire stick not working with encryption
Just got my GL-MT300N and I love this little decvice. I am using tethering with my cellphone and everything is working great so for except one thing. I cannot get my firestick to connect to my network. I am using the default ssid and password. I have also tried changing the ssid and password and changing the encryption from wpa to wpa2 to mix. all my other devices connect just fine, a laptop phone kindle. However if I go to advanced settings and remove the encryption it will connect just fine. I of course want to use encryption. here is the log while the firestick tries to connect.
Sat Apr 23 03:11:17 2016 daemon.info dnsmasq[3521]: reading /tmp/resolv.conf.auto
Sat Apr 23 03:11:17 2016 daemon.info dnsmasq[3521]: using local addresses only for domain lan
Sat Apr 23 03:11:17 2016 daemon.info dnsmasq[3521]: using nameserver 192.168.42.129#53
Sat Apr 23 03:11:17 2016 daemon.info dnsmasq[3521]: read /etc/hosts - 1 addresses
Sat Apr 23 03:11:17 2016 daemon.info dnsmasq[3521]: read /tmp/hosts/dhcp - 1 addresses
Sat Apr 23 03:11:17 2016 daemon.info dnsmasq[3521]: read /tmp/hosts/odhcpd - 1 addresses
Sat Apr 23 03:11:17 2016 daemon.info dnsmasq-dhcp[3521]: read /etc/ethers - 0 addresses
Sat Apr 23 03:11:17 2016 daemon.err miniupnpd[3547]: could not open lease file: /var/upnp.leases
Sat Apr 23 03:11:17 2016 daemon.notice miniupnpd[3547]: HTTP listening on port 5000
Sat Apr 23 03:11:17 2016 daemon.notice miniupnpd[3547]: HTTP IPv6 address given to control points : [fd7b:d0d5:774::1]
Sat Apr 23 03:11:17 2016 daemon.notice miniupnpd[3547]: Listening for NAT-PMP/PCP traffic on port 5351
Sat Apr 23 03:11:56 2016 kern.info kernel: [ 794.760000] device wlan0 left promiscuous mode
Sat Apr 23 03:11:56 2016 kern.info kernel: [ 794.760000] br-lan: port 2(wlan0) entered disabled state
Sat Apr 23 03:11:56 2016 daemon.notice netifd: Network device ‘wlan0’ link is down
Sat Apr 23 03:11:56 2016 daemon.notice netifd: radio0 (4612): command failed: Operation not supported (-122)
Sat Apr 23 03:11:56 2016 daemon.notice netifd: radio0 (4612): Configuration file: /var/run/hostapd-phy0.conf
Sat Apr 23 03:11:56 2016 kern.info kernel: [ 795.280000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Sat Apr 23 03:11:56 2016 kern.info kernel: [ 795.290000] device wlan0 entered promiscuous mode
Sat Apr 23 03:11:56 2016 kern.info kernel: [ 795.290000] br-lan: port 2(wlan0) entered forwarding state
Sat Apr 23 03:11:56 2016 kern.info kernel: [ 795.300000] br-lan: port 2(wlan0) entered forwarding state
Sat Apr 23 03:11:56 2016 daemon.notice netifd: radio0 (4612): wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Sat Apr 23 03:11:56 2016 daemon.notice netifd: radio0 (4612): Using interface wlan0 with hwaddr e4:95:6e:40:72:20 and ssid “GL-MT300N-220”
Sat Apr 23 03:11:57 2016 kern.info kernel: [ 795.520000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Sat Apr 23 03:11:57 2016 daemon.notice netifd: radio0 (4612): wlan0: interface state COUNTRY_UPDATE->ENABLED
Sat Apr 23 03:11:57 2016 daemon.notice netifd: radio0 (4612): wlan0: AP-ENABLED
Sat Apr 23 03:11:57 2016 daemon.notice netifd: Network device ‘wlan0’ link is up
Sat Apr 23 03:11:58 2016 kern.info kernel: [ 797.300000] br-lan: port 2(wlan0) entered forwarding state
Mon May 30 15:11:44 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 IEEE 802.11: authenticated
Mon May 30 15:11:44 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 IEEE 802.11: associated (aid 1)
Mon May 30 15:11:44 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 WPA: pairwise key handshake completed (RSN)
Mon May 30 15:12:50 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: authenticated
Mon May 30 15:12:50 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: associated (aid 2)
Mon May 30 15:12:50 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f WPA: pairwise key handshake completed (RSN)
Mon May 30 15:13:21 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: disassociated
Mon May 30 15:13:22 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Mon May 30 15:13:23 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: authenticated
Mon May 30 15:13:23 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: associated (aid 2)
Mon May 30 15:13:23 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f WPA: pairwise key handshake completed (RSN)
Mon May 30 15:13:54 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: disassociated
Mon May 30 15:13:55 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Mon May 30 15:13:56 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: authenticated
Mon May 30 15:13:56 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: associated (aid 2)
Mon May 30 15:13:56 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f WPA: pairwise key handshake completed (RSN)
Mon May 30 15:14:27 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: disassociated
Mon May 30 15:14:28 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Mon May 30 15:14:29 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: authenticated
Mon May 30 15:14:29 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: associated (aid 2)
Mon May 30 15:14:29 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f WPA: pairwise key handshake completed (RSN)
Mon May 30 15:15:00 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: disassociated
Mon May 30 15:15:01 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Mon May 30 15:15:02 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: authenticated
Mon May 30 15:15:02 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: associated (aid 2)
Mon May 30 15:15:02 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f WPA: pairwise key handshake completed (RSN)
Mon May 30 15:15:25 2016 kern.info kernel: [ 1030.720000] device wlan0 left promiscuous mode
Mon May 30 15:15:25 2016 kern.info kernel: [ 1030.730000] br-lan: port 2(wlan0) entered disabled state
Mon May 30 15:15:25 2016 daemon.notice netifd: radio0 (9584): command failed: Operation not supported (-122)
Mon May 30 15:15:25 2016 daemon.notice netifd: radio0 (9584): Configuration file: /var/run/hostapd-phy0.conf
Mon May 30 15:15:26 2016 kern.info kernel: [ 1031.470000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Mon May 30 15:15:26 2016 kern.info kernel: [ 1031.480000] device wlan0 entered promiscuous mode
Mon May 30 15:15:26 2016 kern.info kernel: [ 1031.480000] br-lan: port 2(wlan0) entered forwarding state
Mon May 30 15:15:26 2016 kern.info kernel: [ 1031.490000] br-lan: port 2(wlan0) entered forwarding state
Mon May 30 15:15:26 2016 daemon.notice netifd: radio0 (9584): wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Mon May 30 15:15:26 2016 daemon.notice netifd: radio0 (9584): Using interface wlan0 with hwaddr e4:95:6e:40:72:20 and ssid “GL-MT300N-220”
Mon May 30 15:15:26 2016 kern.info kernel: [ 1031.710000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Mon May 30 15:15:26 2016 daemon.notice netifd: radio0 (9584): wlan0: interface state COUNTRY_UPDATE->ENABLED
Mon May 30 15:15:26 2016 daemon.notice netifd: radio0 (9584): wlan0: AP-ENABLED
Mon May 30 15:15:26 2016 daemon.notice netifd: Network device ‘wlan0’ link is up
Mon May 30 15:15:27 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 IEEE 802.11: authenticated
Mon May 30 15:15:27 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 IEEE 802.11: associated (aid 1)
Mon May 30 15:15:27 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 WPA: pairwise key handshake completed (RSN)
Mon May 30 15:15:28 2016 kern.info kernel: [ 1033.490000] br-lan: port 2(wlan0) entered forwarding state
Mon May 30 15:15:28 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: authenticated
Mon May 30 15:15:28 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: associated (aid 2)
Mon May 30 15:15:28 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f WPA: pairwise key handshake completed (RSN)
Mon May 30 15:15:33 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: disassociated
Mon May 30 15:15:34 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Mon May 30 15:15:42 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: authenticated
Mon May 30 15:15:42 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: associated (aid 2)
Mon May 30 15:15:42 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f WPA: pairwise key handshake completed (RSN)
Mon May 30 15:15:58 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: disassociated
Mon May 30 15:15:59 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Mon May 30 15:17:35 2016 daemon.info hostapd: wlan0: STA a0:02:dc:ec:38:f8 IEEE 802.11: authenticated
Mon May 30 15:17:35 2016 daemon.info hostapd: wlan0: STA a0:02:dc:ec:38:f8 IEEE 802.11: associated (aid 2)
Mon May 30 15:17:35 2016 daemon.info hostapd: wlan0: STA a0:02:dc:ec:38:f8 WPA: pairwise key handshake completed (RSN)
Mon May 30 15:17:35 2016 daemon.info dnsmasq-dhcp[3521]: DHCPREQUEST(br-lan) 192.168.8.128 a0:02:dc:ec:38:f8
Mon May 30 15:17:35 2016 daemon.info dnsmasq-dhcp[3521]: DHCPACK(br-lan) 192.168.8.128 a0:02:dc:ec:38:f8 kindle-4c65b30cc
Mon May 30 15:25:26 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 WPA: group key handshake completed (RSN)
Mon May 30 15:25:27 2016 daemon.info hostapd: wlan0: STA a0:02:dc:ec:38:f8 WPA: group key handshake completed (RSN)
Mon May 30 15:31:55 2016 kern.info kernel: [ 2020.790000] device wlan0 left promiscuous mode
Mon May 30 15:31:55 2016 kern.info kernel: [ 2020.800000] br-lan: port 2(wlan0) entered disabled state
Mon May 30 15:31:57 2016 daemon.notice netifd: radio0 (14890): command failed: Operation not supported (-122)
Mon May 30 15:31:57 2016 daemon.notice netifd: radio0 (14890): Configuration file: /var/run/hostapd-phy0.conf
Mon May 30 15:31:57 2016 kern.info kernel: [ 2023.070000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Mon May 30 15:31:57 2016 daemon.notice netifd: radio0 (14890): wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Mon May 30 15:31:57 2016 kern.info kernel: [ 2023.110000] device wlan0 entered promiscuous mode
Mon May 30 15:31:57 2016 daemon.notice netifd: radio0 (14890): Using interface wlan0 with hwaddr e4:95:6e:40:72:20 and ssid “GL-MT300N-220”
Mon May 30 15:31:58 2016 kern.info kernel: [ 2023.770000] br-lan: port 2(wlan0) entered forwarding state
Mon May 30 15:31:58 2016 kern.info kernel: [ 2023.780000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Mon May 30 15:31:58 2016 daemon.notice netifd: radio0 (14890): wlan0: interface state COUNTRY_UPDATE->ENABLED
Mon May 30 15:31:58 2016 daemon.notice netifd: radio0 (14890): wlan0: AP-ENABLED
Mon May 30 15:31:58 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 IEEE 802.11: authenticated
Mon May 30 15:31:58 2016 daemon.notice netifd: Network device ‘wlan0’ link is up
Mon May 30 15:31:59 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 IEEE 802.11: authenticated
Mon May 30 15:31:59 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 IEEE 802.11: associated (aid 1)
Mon May 30 15:31:59 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 WPA: pairwise key handshake completed (WPA)
Mon May 30 15:31:59 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 WPA: group key handshake completed (WPA)
Mon May 30 15:31:59 2016 daemon.err insmod: module is already loaded - xt_multiport
Mon May 30 15:31:59 2016 daemon.err insmod: module is already loaded - xt_comment
Mon May 30 15:31:59 2016 daemon.err insmod: module is already loaded - xt_length
Mon May 30 15:32:00 2016 kern.info kernel: [ 2025.770000] br-lan: port 2(wlan0) entered forwarding state
Mon May 30 15:32:22 2016 kern.info kernel: [ 2047.480000] device wlan0 left promiscuous mode
Mon May 30 15:32:22 2016 kern.info kernel: [ 2047.480000] br-lan: port 2(wlan0) entered disabled state
Mon May 30 15:32:22 2016 daemon.notice netifd: Network device ‘wlan0’ link is down
Mon May 30 15:32:22 2016 daemon.notice netifd: radio0 (15725): command failed: Operation not supported (-122)
Mon May 30 15:32:22 2016 daemon.notice netifd: radio0 (15725): Configuration file: /var/run/hostapd-phy0.conf
Mon May 30 15:32:22 2016 kern.info kernel: [ 2048.020000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Mon May 30 15:32:22 2016 kern.info kernel: [ 2048.030000] device wlan0 entered promiscuous mode
Mon May 30 15:32:22 2016 kern.info kernel: [ 2048.030000] br-lan: port 2(wlan0) entered forwarding state
Mon May 30 15:32:22 2016 kern.info kernel: [ 2048.040000] br-lan: port 2(wlan0) entered forwarding state
Mon May 30 15:32:22 2016 daemon.notice netifd: radio0 (15725): wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Mon May 30 15:32:22 2016 daemon.notice netifd: radio0 (15725): Using interface wlan0 with hwaddr e4:95:6e:40:72:20 and ssid “GL-MT300N-220”
Mon May 30 15:32:22 2016 kern.info kernel: [ 2048.260000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Mon May 30 15:32:22 2016 daemon.notice netifd: radio0 (15725): wlan0: interface state COUNTRY_UPDATE->ENABLED
Mon May 30 15:32:22 2016 daemon.notice netifd: radio0 (15725): wlan0: AP-ENABLED
Mon May 30 15:32:22 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 IEEE 802.11: authenticated
Mon May 30 15:32:22 2016 daemon.notice netifd: Network device ‘wlan0’ link is up
Mon May 30 15:32:23 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 IEEE 802.11: authenticated
Mon May 30 15:32:23 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 IEEE 802.11: associated (aid 1)
Mon May 30 15:32:23 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 WPA: pairwise key handshake completed (WPA)
Mon May 30 15:32:24 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 WPA: group key handshake completed (WPA)
Mon May 30 15:32:24 2016 kern.info kernel: [ 2050.040000] br-lan: port 2(wlan0) entered forwarding state
Mon May 30 15:33:50 2016 kern.info kernel: [ 2136.270000] device wlan0 left promiscuous mode
Mon May 30 15:33:50 2016 kern.info kernel: [ 2136.280000] br-lan: port 2(wlan0) entered disabled state
Mon May 30 15:33:51 2016 daemon.notice netifd: radio0 (17875): command failed: Operation not supported (-122)
Mon May 30 15:33:51 2016 daemon.notice netifd: radio0 (17875): Configuration file: /var/run/hostapd-phy0.conf
Mon May 30 15:33:51 2016 kern.info kernel: [ 2136.980000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Mon May 30 15:33:51 2016 kern.info kernel: [ 2136.990000] device wlan0 entered promiscuous mode
Mon May 30 15:33:51 2016 kern.info kernel: [ 2136.990000] br-lan: port 2(wlan0) entered forwarding state
Mon May 30 15:33:51 2016 kern.info kernel: [ 2137.000000] br-lan: port 2(wlan0) entered forwarding state
Mon May 30 15:33:51 2016 daemon.notice netifd: radio0 (17875): wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Mon May 30 15:33:51 2016 daemon.notice netifd: radio0 (17875): Using interface wlan0 with hwaddr e4:95:6e:40:72:20 and ssid “GL-MT300N-220”
Mon May 30 15:33:51 2016 kern.info kernel: [ 2137.220000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Mon May 30 15:33:51 2016 daemon.notice netifd: radio0 (17875): wlan0: interface state COUNTRY_UPDATE->ENABLED
Mon May 30 15:33:51 2016 daemon.notice netifd: radio0 (17875): wlan0: AP-ENABLED
Mon May 30 15:33:51 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 IEEE 802.11: authenticated
Mon May 30 15:33:51 2016 daemon.notice netifd: Network device ‘wlan0’ link is up
Mon May 30 15:33:52 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 IEEE 802.11: authenticated
Mon May 30 15:33:52 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 IEEE 802.11: associated (aid 1)
Mon May 30 15:33:52 2016 daemon.info hostapd: wlan0: STA 00:26:c7:f9:05:a6 WPA: pairwise key handshake completed (RSN)
Mon May 30 15:33:53 2016 kern.info kernel: [ 2139.000000] br-lan: port 2(wlan0) entered forwarding state
Mon May 30 15:34:01 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: authenticated
Mon May 30 15:34:01 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: associated (aid 2)
Mon May 30 15:34:01 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f WPA: pairwise key handshake completed (RSN)
Mon May 30 15:34:32 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: disassociated
Mon May 30 15:34:33 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Mon May 30 15:34:34 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: authenticated
Mon May 30 15:34:34 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: associated (aid 2)
Mon May 30 15:34:34 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f WPA: pairwise key handshake completed (RSN)
Mon May 30 15:35:05 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: disassociated
Mon May 30 15:35:06 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Mon May 30 15:35:07 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: authenticated
Mon May 30 15:35:07 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: associated (aid 2)
Mon May 30 15:35:07 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f WPA: pairwise key handshake completed (RSN)
Mon May 30 15:35:38 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: disassociated
Mon May 30 15:35:39 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Mon May 30 15:35:40 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: authenticated
Mon May 30 15:35:40 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: associated (aid 2)
Mon May 30 15:35:40 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f WPA: pairwise key handshake completed (RSN)
I checked on google. Seems this is a problem of wmm.
Can you set wwm to ‘0’ and try again?
You can do this in Luci.
You can also do it via ssh, add the following content to /etc/config/wireless
option ‘wmm’ ‘0’
I unchecked wmm mode in the advanced settings and I am still getting the same issue.
Wed Jun 1 21:20:05 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: authenticated
Wed Jun 1 21:20:05 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: associated (aid 2)
Wed Jun 1 21:20:05 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f WPA: pairwise key handshake completed (RSN)
Wed Jun 1 21:20:37 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: disassociated
Wed Jun 1 21:20:38 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Wed Jun 1 21:20:39 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: authenticated
Wed Jun 1 21:20:39 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: associated (aid 2)
Wed Jun 1 21:20:39 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f WPA: pairwise key handshake completed (RSN)
Wed Jun 1 21:20:48 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: disassociated
Wed Jun 1 21:20:49 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Wed Jun 1 21:21:15 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: authenticated
Wed Jun 1 21:21:15 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: associated (aid 2)
Wed Jun 1 21:21:15 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f WPA: pairwise key handshake completed (RSN)
Wed Jun 1 21:21:46 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: disassociated
Wed Jun 1 21:21:47 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Wed Jun 1 21:21:48 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: authenticated
Wed Jun 1 21:21:48 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: associated (aid 2)
Wed Jun 1 21:21:49 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f WPA: pairwise key handshake completed (RSN)
Wed Jun 1 21:22:19 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: disassociated
Wed Jun 1 21:22:20 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Wed Jun 1 21:22:22 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: authenticated
Wed Jun 1 21:22:22 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f IEEE 802.11: associated (aid 2)
Wed Jun 1 21:22:22 2016 daemon.info hostapd: wlan0: STA f0:27:2d:1f:15:5f WPA: pairwise key handshake completed (RSN)
I don’t have a fire stick and don’t know what is the problem.
