Anonymous IP Address
Hi :wave:, I’m not able to connect to company VPN anymore because I have anonymous up address or using anonymous device resolving for a different country. Any solution for this? I’m using Azir wireguard
If your company VPN is blocking your own VPN, there are only 2 solutions:
  1. Try to utilize a fitting VPN policy (maybe Based on the target domain or IP)
  2. Disabling VPN while being connected to your company.
Google split tunneling for the VPN protocol you’re using.
Connect back to home and use double vpn?
Thank you Admon. I’ll try the first option with a friend. I’m not very technical but I switched back to the 1300 device and it started to work.
Thank you. I’ll give it a try once I’m back to the US and access the device. I’m using the 1300 model and it’s connecting so far
