I really like my AR150, however, it doesn’t have ethernet speeds that I need to use it as my main router on my LAN. I have a fiber connection into my home with 1G speeds, so I’d like to have hardware that supports 1G. Do you guys manufacture anything that supports those speeds?
When are you expecting these to become available? I am interested in dual 1Gb NIC devices. Also, any idea of pricing yet?
I am asking because we need to settle on a manufacturer asap as we continue working on our code. At the moment, we have been testing several manufacturers and so far, the MT300N seems a good fit, only we need a similar device with two gb ports.
Thanks. We’ll have to find something else in the meantime I guess. If you have any kind of beta tester program, please let me know about it as we always run these for weeks/months before sending them to customers after putting our own build on them.
will the new models be able to work with higher speeds? any updates on eta?
I currently got speeds with vpn of about 6-8 mbit/s (with GL-AR300M external antenna). My vpn is gbit and with openvpn on my laptop I can get the full 100mbit/s (24/7) of my internet line. Will the new model be able to give me this speed, too?
OpenVPN speeds are more a function of the CPU, memory and encryption than the line speed. Wired vs wireless also play in. The CPU speed, number of cores and memory are 4-8 times that of the typical router in addition most current CPUs have hardware encryption on the chip (AES).
Are you wireless on the WAN side too? No, LAN cable
Are you on a service, if so what? I don’t understand that question. If my VPN is a service?
@ alzhao:
“The new router can achieve better VPN speed”.
–> Do you already have speedtest results? I would love maybe a GL-AR750M (PRO). With AC Wlan, gbit lan/wan port, passive cooled and enough speed to handle full 100mbit vpn .
edit:
now tested with LAN/WLAN: both pending between 7-8 mbit/s with openvpn active…
