Any one from DK with GL-E750
Any one that can confirm this the correct setting for 3.dk and Muddi GL-E750?
It performs bad on a good place only 50% comparred to my cellphone on 4g.
Thanks,
Nenad
Hi Nedad,
You have the CAT4 or CAT6 Version? Even with CAT6 you will not have same performance like on a mobile CAT19.
CAT4 is the basic LTE and CAT6 will agregate only 2 LTE bands.
About what performance are you talking? On your mobile you have more than 100Mbps and Mudi 50% less? This is not bad performance for such device.
Hi Nedad,
5G phones typically support LTE CAT19, which has higher speeds compared to the CAT6 or CAT4 versions of the GL-E750. Therefore, when using the phone as a cellular network source and sharing internet connection, you may experience faster data rates with the phone than with the GL-E750 router.
Here is a comparison of the maximum speeds for different standards:
LTE CAT19: Max 1.6Gbps (DL)/200Mbps (UL)
LTE CAT12: Max 600Mbps (DL)/150Mbps (UL)
LTE CAT6: Max 300Mbps (DL)/50Mbps (UL)
LTE CAT4: Max 150Mbps (DL)/50Mbps (UL)
