Want to use my edgerouter X behind the Spitz and have the Spitz as a modem only. Any way to put it into a bridged or passthrough mode?
It cannot be put in passthrough mode.
Just to clarify, so this cannot be done from 4G/LTE to LAN? For the router to just pass the internet and not do DHCP or NAT?
What about for a wired modem on WAN to pass the internet to the LAN? Does the answer to this question apply to all the routers: Spitz, Slate, AR150, AR300, etc.?
Some posts seem to say that it is possible to use Access Point mode for this purpose but some others say no.
Thank you.
4G/LTE to LAN bridge is not possible on our router.
But hostless modem bridge is possible.
Can you elaborate on what that is and how to set it up?
I mean “hostless modem”. Sorry I made a typo.
Hostless modem itself is a host, with dhcp, gateway. By default you can set up as tethering in the router. Then you can change it to bridge in luci manually.
