Hello team, is there any plan for next 3-6 months for a wifi 7 device based GL-X3000 / Spitz AX?
I have now about 4x "GL-X3000 / Spitz AX" and i love them but for new purchases i will purchase only wifi 7 devices... any news regarding that?
There is wifi 7 device planned.
But why do you need wifi 7 for the 5G router specifically? Understood that you have 4 already but do you have any problems with wifi 6?
You won't need wifi 7 for at least a year. But Slate 7 which is a travel router will have wifi 7.
Anything with the 6Ghz band or only WiFi 7 2.4Ghz and 5Ghz?
I'm curious which cellular carrier you are using that provides greater than wifi 6 speeds?
I use the GL-X3000 as the main router in different houses. I will use the router next 2-3 years at least. Which means if i buy a new device with wifi 6 i will regret that in 1-2 years when i will have several wifi 7 devices but they will be slow as the router can only go with wifi 6.
So it make sense to buy wifi 7 devices from now in order to not regret it in one year.
Also it will be a pain in the ass if i add router from other company to my enviroment as i have to maintain diferent plattforms... so the best case for me would be to get a new GL router with 5g cellular and wifi 7
for sure with 6Ghz to use full wifi 7 speed
In Local Network it is very nice to have wifi 7 between devices
If you really regret buying Wi-Fi 6 instead of 7, I would like to introduce to our lord and savior: Ethernet.
Everyone should have Ethernet on cat7 cable... but sadly i can not dig holes in every wall... i would kill to have all devices on cat7 but sadly it is not always possible
