AR 150 extroot tutorial
Ive been trying to do an extroot with a 16 gig usb who has been formated to ext4 every time I try to mount the usb partition I get errors.
Is there any tutorial out there that someone could share for this router
Thanks
what is the error?
I am following this eDIY - How to increase storage on TP-Link TL-MR3020 with ExtRoot tutorial
when I try to mount the ext4 i get this error
root@GL-AR150:~# mount /dev/sda1 /mnt/sda1
mount: mount(2) failed: No such file or directory
block info
root@GL-AR150:~# block info
/dev/mtdblock4: UUID=“5b6d94f3-d199acd5-28930981-d4a7658c” VERSION=“4.0” TYPE=“squashfs”
/dev/mtdblock5: TYPE=“jffs2”
/dev/sda1: UUID=“a0fb4f2a-6588-4541-a30e-58540b981ee5” NAME=“EXT_JOURNAL” VERSION=“1.0” TYPE=“ext4”
/dev/sda2: UUID=“bff55657-13ec-4a76-9238-a7d8562850f8” VERSION=“1” TYPE=“swap”
is there a tutorial or a pluging or a script to do extroot ?
Thanks
