Hi All
I can’t connect my PC to new AR-750M router, the network connection constantly connects and disconnects showing “cable not connected” message. Tried different PCs, patch-cords, reset the router. Nothing helps. No wifi network also. The power LED is on but otherwise it looks completely dead. Any thoughts on that or should i ship the device back?
Is there insufficient power supply for it? Could you confirm that you use the standard adapter?
Aye, i tried it with AC adapter and with PC USB port.
The AC adapter is 5V/2A? If there still has problem, you can contact the seller to return it.
That won’t provide enough juice.
Yes, it can. Is the device bricked?
I assume that this problem was solved.
