Transmission stopped working after the 3.0.9 → 3.0.25 upgrade. Anyone figured it out? Where is the log of that thing?
Did you check the transmission version?
Whatever comes from the plugins - 2.93.7. Used to work with the previous firmware.
How well does…did it perform on the Slate ?
With 3.0.9 it was … ok?
Maybe you can re-install the plug-in? I don’t think the package is changed.
I have eliminated all basic stuff - restart, reinstall, etc. - before writing here. I thought it was assumed.
Has anyone made it work? Where can I find the logs?
