Can someone tell me how to log back in my router before I throw this piece of crap in the garbage. Downloaded the update and it shut me out now I can’t even get to a login in page. Why would you even make something that can’t be used
This forum is not a glinet customer service. There are some glinet staff active and helpful here, there are also some other users/customers very knowledgeable and with some valuable experience, however they all want to feel that their time that they invest in helping you is at least appreciated.
I understand that you had an issue and you may need to vent, however if you do it then do it in an acceptable way
Hey mate, don’t know what’s happened however you could try:
Reset
Failing that you’re probably best to uboot a fresh copy of the firmware.
