Is there a way to power off/suspend to RAM/suspend to flash the AR150?
Ideally I’d like to put the AR150 to sleep (or power it off) and wake it up via a GPIO pin.
Is that possible? Any ideas?
Cheers.
Cheers.
I don’t think this is an option though you could perhaps power down wifi to reduce energy usage.
And set LED’s off as default.
Maybe have a look in the AR9331 datasheet if there is a way to lower the clock frequency.
I think it’s very complex,And I don’t think it will work well on AR150. AR150 is based on AR9331.It’s just a router Soc.
