Ar300
I use ar300. I want to connect device with static ip to lan ar300. How conf network with static ip on ar300?
If your version is 3.x, you can go to the LAN IP menu under MORE SETTINGS, select the MAC address, enter the IP, and click “Add” .
If your version is 4.x, you can go to the LAN menu under NETWORK, click on the “Add” button, select the MAC address, enter the IP, and click on “Submit”.
You can check the file below.
ar300.zip (195.4 KB)
How forward multicast trafic from static ip adress for ar300?
