Hi.
I have an AR300M and have testing 3.104 firmware loaded, using USB tethering.
I have VPN, DNS (over TLS), Kill-Switch all enabled.
The VPN often fails to connect at first boot (or reboot) but works fine if I then login to the Web Interface and click “abort” then “connect”.
Any thoughts or ideas on what the problem is?
Thanks!
Log:
Wed May 27 08:20:10 2020 daemon.notice procd: /etc/rc.d/S99startvpn: well
Wed May 27 08:20:10 2020 daemon.notice procd: /etc/rc.d/S99startvpn: Warning: Section @zone[1] (wan) cannot resolve device of network ‘wan6’
Wed May 27 08:20:10 2020 daemon.notice procd: /etc/rc.d/S99startvpn: Warning: Section @zone[1] (wan) cannot resolve device of network ‘modem_1_1’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Clearing IPv4 filter table
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Clearing IPv4 nat table
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Clearing IPv4 mangle table
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Populating IPv4 filter table
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Rule ‘Allow-DHCP-Renew’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Rule ‘Allow-Ping’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Rule ‘Allow-IGMP’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Rule ‘Allow-IPSec-ESP’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Rule ‘Allow-ISAKMP’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Rule ‘guestzone_DHCP’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Rule ‘guestzone_DNS’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Rule ‘safe_mode_lan’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Rule ‘safe_mode_guest’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Forward ‘lan’ → ‘ovpn’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Forward ‘guestzone’ → ‘ovpn’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Zone ‘lan’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Zone ‘wan’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Zone ‘guestzone’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Zone ‘ovpn’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Populating IPv4 nat table
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Populating IPv4 mangle table
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Clearing IPv6 filter table
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Clearing IPv6 mangle table
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Populating IPv6 filter table
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Rule ‘Allow-DHCPv6’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Rule ‘Allow-MLD’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Rule ‘Allow-ICMPv6-Input’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Rule ‘Allow-ICMPv6-Forward’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Populating IPv6 mangle table
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Set tcp_ecn to off
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Set tcp_syncookies to on
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Set tcp_window_scaling to on
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Running script ‘/etc/firewall.user’
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: iptables: No chain/target/match by that name.
Wed May 27 08:20:12 2020 daemon.notice procd: /etc/rc.d/S99startvpn: ipset v6.34: The set with the given name does not exist
Wed May 27 08:20:13 2020 daemon.notice procd: /etc/rc.d/S99startvpn: iptables v1.6.2: can’t initialize iptables table raw': Table does not exist (do you need to insmod?) Wed May 27 08:20:13 2020 daemon.notice procd: /etc/rc.d/S99startvpn: Perhaps iptables or your kernel needs to be upgraded. Wed May 27 08:20:13 2020 daemon.notice procd: /etc/rc.d/S99startvpn: iptables v1.6.2: can't initialize iptables table
raw’: Table does not exist (do you need to insmod?)
Wed May 27 08:20:13 2020 daemon.notice procd: /etc/rc.d/S99startvpn: ! Failed with exit code 3
Wed May 27 08:20:13 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Running script ‘/usr/bin/glfw.sh’
Wed May 27 08:20:13 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Running script ‘/var/etc/gls2s.include’
Wed May 27 08:20:13 2020 daemon.notice procd: /etc/rc.d/S99startvpn: ! Skipping due to path error: No such file or directory
Wed May 27 08:20:13 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Running script ‘/usr/sbin/glqos.sh’
Wed May 27 08:20:14 2020 daemon.notice procd: /etc/rc.d/S99startvpn: * Running script ‘/var/etc/mwan3.include’
Wed May 27 08:20:15 2020 daemon.notice openvpn[3970]: OpenVPN 2.4.5 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Wed May 27 08:20:15 2020 daemon.notice openvpn[3970]: library versions: OpenSSL 1.0.2o 27 Mar 2018, LZO 2.10
Wed May 27 08:20:15 2020 daemon.warn openvpn[4007]: WARNING: No server certificate verification method has been enabled. See How To Guide: Set Up & Configure OpenVPN Client/server VPN | OpenVPN for more info.
Wed May 27 08:20:15 2020 daemon.warn openvpn[4007]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Wed May 27 08:20:15 2020 daemon.notice openvpn[4007]: TCP/UDP: Preserving recently used remote address: [AF_INET]xx.xx.xx.xx:1194
Wed May 27 08:20:15 2020 daemon.notice openvpn[4007]: Socket Buffers: R=[163840->163840] S=[163840->163840]
Wed May 27 08:20:15 2020 daemon.notice openvpn[4007]: UDP link local: (not bound)
Wed May 27 08:20:15 2020 daemon.notice openvpn[4007]: UDP link remote: [AF_INET]xx.xx.xx.xx:1194
Wed May 27 08:20:15 2020 daemon.notice openvpn[4007]: TLS: Initial packet from [AF_INET]xx.xxx.xxx.xx:1194, sid=xxxxxxx xxxxxxx
Wed May 27 08:20:15 2020 daemon.warn openvpn[4007]: WARNING: this configuration may cache passwords in memory – use the auth-nocache option to prevent this
Wed May 27 08:20:15 2020 daemon.info procd: - init complete -
Wed May 27 08:20:15 2020 daemon.notice openvpn[4007]: VERIFY OK:
Wed May 27 08:20:16 2020 daemon.notice openvpn[4007]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 1024 bit RSA
Wed May 27 08:20:16 2020 daemon.notice openvpn[4007]: [server] Peer Connection Initiated with [AF_INET]xx.xx.xx.xx:1194
Wed May 27 08:20:17 2020 daemon.notice openvpn[4007]: SENT CONTROL [server]: ‘PUSH_REQUEST’ (status=1)
Wed May 27 08:20:22 2020 daemon.notice openvpn[4007]: SENT CONTROL [server]: ‘PUSH_REQUEST’ (status=1)
Wed May 27 08:20:23 2020 kern.notice kernel: [ 85.933928] random: crng init done
Wed May 27 08:20:23 2020 kern.notice kernel: [ 85.937462] random: 6 urandom warning(s) missed due to ratelimiting
Wed May 27 08:20:25 2020 daemon.notice openvpn[4007]: AUTH: Received control message: AUTH_FAILED
Wed May 27 08:20:25 2020 daemon.notice openvpn[4007]: SIGTERM[soft,auth-failure] received, process exiting
In VPN section of Web UI: “VPN client failed to connect. This may be because of wrong configuration, unsupported parameters or terminated by the server. Please choose another VPN profile or abort the connection.”
