and flashed it like described here(md5sum looked O.K.):
Via UART Serial I issued:
ath> run lu
Trying eth0
eth0 link down
FAIL
Trying eth1
enet1 port0 up
dup 1 speed 1000
Using eth1 device
TFTP from server 192.168.1.2; our IP address is 192.168.1.1
Filename ‘uboot-gl-ar300m.bin’.
Load address: 0x80060000
Loading: #############
done
Bytes transferred = 65679 (1008f hex)
Erasing flash…
First 0x0 last 0x4 sector size 0x10000
4
Erased 5 sectors
Copy to Flash… write addr: 9f000000
done�
Since this action the AR300M-ext is just lighting the three LEDs when you power it.
So something went terribly wrong.
Is there a JTAG where the broken Bootloader can be fixed?
Or another way to recover this?
I am also interested since I have the same problem with a destroyed uboot and all three leds on. I got exactly the same msg yesterday
I think the flash is on the backside with 2x4 contacts. Mine is from Winbond. There are adapters to flash it without having to desolder it. But I do not know how good they are and how to re-flash it.
