I have acquired an AR300M and am thinking of using it in IoT applications.
I need access to the serial console, but can use the I2C pads as GPIO. Which gives me 2 IOs.
But when I look at the motherboard (https://www.gl-inet.com/ar300m/#1442566013976-f19448f7-2698), I note that GPIOs 15, 11, 8-3 are not mentioned.
Might they be in any way connected to the “PCIE” connector? If some of them are, that would make the device much more capable, in terms of IOs.
In addition, GPIO13 is connected both to a LED and to a switch. Could that circuitry be clarified)
Thanks in advance
