编译镜像的源是 GitHub - gl-inet/lede-imagebuilder-ar71xx-nand: LEDE imagebuilder for ar71xx nand.
编译固件命令
make image PROFILE=“GL-AR300MNAND” PACKAGES=“luci kmod-fs-ext4 kmod-fs-ntfs kmod-fs-vfat kmod-fs-exfat ntfs-3g kmod-nls-cp437 kmod-nls-iso8859-1 kmod-nls-utf8 kmod-usb-storage kmod-usb-uhci kmod-usb2 kmod-usb-ohci kmod-usb-net kmod-usb-net-cdc-ether kmod-usb-net-rndis kmod-usb-net-qmi-wwan kmod-usb-acm kmod-usb-net-huawei-cdc-ncm kmod-usb-net-ipheth usb-modeswitch openssl-util”
生成的固件刷入ar300m以后,插入4g网卡,添加 interface时(http://192.168.1.1/cgi-bin/luci/admin/network/iface_add),一直提示 “Form token mismatch” The submitted security token is invalid or already expired!
其他模块也有类似的问题,我简单看了下页面代码,好像是from提交了2次 token
@alzhao 帮忙看一下, 这个问题在lede上普遍存在,不知道是否是固件的问题,还是chrome浏览器的问题。
依然有问题 不只是 GL-AR300MNAND gl-mifi也存在同样的问题。下方是我编译固件的命令。
make image PROFILE="gl-mifi" PACKAGES="luci usb-modeswitch kmod-mii kmod-usb-net kmod-usb-wdm kmod-usb-net-qmi-wwan uqmi luci-proto-3g kmod-usb-serial kmod-usb-serial-option kmod-usb-serial-wwan"
问题复现的步骤。
1、下载固件 GL.iNet download center 并刷入 gl-mifi
2、进入 http://192.168.8.1/cgi-bin/luci/admin/network/iface_add 添加接口。内容随意填写
3、提交以后,提示如下内容
Form token mismatch
In order to prevent unauthorized access to the system, your request has been blocked. Click “Continue »” below to return to the previous page.
4、初步判断是页面多了一段 csrf token
明白了,会查一下。
will have a check
最近有进展吗?hello?
aaaaaaaaaaaa
alzhao
May 24, 2018, 4:30am
10
no.
Let me push the dev team.
@qca9531 Try to pull and build again, I have commit it to github.
