I installed firmware file openwrt-ar300m-3.022-0329.tar on my AR300M.
When wifi is off, the logs are flooded with info messages. About every 20 seconds the following lines appear in the logs:
Sun May 19 14:50:18 2019 kern.info kernel: [ 1217.080777] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Sun May 19 14:50:36 2019 kern.info kernel: [ 1234.909714] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Sun May 19 14:50:54 2019 kern.info kernel: [ 1252.758207] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Sun May 19 14:51:13 2019 kern.info kernel: [ 1271.253411] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Sun May 19 14:51:31 2019 kern.info kernel: [ 1289.763931] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Sun May 19 14:51:50 2019 kern.info kernel: [ 1308.360215] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Sun May 19 14:52:04 2019 kern.info kernel: [ 1322.498388] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Sun May 19 14:52:04 2019 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Sun May 19 14:52:04 2019 kern.info kernel: [ 1322.573053] br-lan: port 2(wlan0) entered blocking state
Sun May 19 14:52:04 2019 kern.info kernel: [ 1322.573067] br-lan: port 2(wlan0) entered disabled state
Sun May 19 14:52:04 2019 kern.info kernel: [ 1322.573441] device wlan0 entered promiscuous mode
Sun May 19 14:52:04 2019 daemon.err hostapd: Using interface wlan0 with hwaddr e4:95:6e:44:88:ac and ssid “H2O-BLACK-WLAN”
Sun May 19 14:52:05 2019 kern.info kernel: [ 1324.112824] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Sun May 19 14:52:05 2019 kern.info kernel: [ 1324.113009] br-lan: port 2(wlan0) entered blocking state
Sun May 19 14:52:05 2019 kern.info kernel: [ 1324.113019] br-lan: port 2(wlan0) entered forwarding state
Sun May 19 14:52:06 2019 daemon.notice hostapd: wlan0: interface state COUNTRY_UPDATE->ENABLED
Sun May 19 14:52:06 2019 daemon.notice hostapd: wlan0: AP-ENABLED
Sun May 19 14:52:06 2019 daemon.notice netifd: Network device ‘wlan0’ link is up
Sun May 19 14:55:19 2019 kern.info kernel: [ 1517.232828] device wlan0 left promiscuous mode
Sun May 19 14:55:19 2019 kern.info kernel: [ 1517.232947] br-lan: port 2(wlan0) entered disabled state
Sun May 19 14:55:19 2019 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Sun May 19 14:55:19 2019 daemon.notice hostapd: wlan0: AP-DISABLED
Sun May 19 14:55:19 2019 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Sun May 19 14:55:19 2019 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Sun May 19 14:55:19 2019 daemon.notice hostapd: nl80211: Failed to remove interface wlan0 from bridge br-lan: Invalid argument
Sun May 19 14:55:29 2019 kern.info kernel: [ 1527.490228] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Sun May 19 14:55:48 2019 kern.info kernel: [ 1546.220650] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Sun May 19 14:55:49 2019 kern.info kernel: [ 1547.921050] IPv6: ADDRCONF(NETDEV_UP): tmp.phy0: link is not ready
Sun May 19 14:56:07 2019 kern.info kernel: [ 1566.158836] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Sun May 19 14:56:25 2019 kern.info kernel: [ 1583.994455] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Sun May 19 14:56:43 2019 kern.info kernel: [ 1601.923571] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Sun May 19 14:57:01 2019 kern.info kernel: [ 1619.838211] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Sun May 19 14:57:19 2019 kern.info kernel: [ 1637.661240] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
Sun May 19 14:57:37 2019 kern.info kernel: [ 1655.498527] IPv6: ADDRCONF(NETDEV_UP): tmp.radio0: link is not ready
When I set wifi on, the log entries do no appear (see above at 14:52:06). I do not use any ipv6 addresses in my home lan, so every ipv6 related configuration value is untouched (factory default values).
How can I stop the above log entries in the mode “wifi off”.
Barney
